    Any advice would be greatly appreciated. I have just purchased a little cnc router for PCB work.
    I have been trying different layout options while I wait for cables and connectors to turn up
    There are three options that I can see and wondered if there are any issues with these, like electrical interference, heat concerns/ventilation or anything I may have missed.
    Options 1 and 3 involved mounting the BOB onto acrylic and attaching this to the door panel.
    The external case dimensions are 400mm x 300mm x 150mm but the removable steal base panel is 350 x 250 which is what I want to keep all the electrics on for ease of removal. All the connetors wil be mounted on the access panel on the side
    Option 1 - and preferred option for me
    Option 2
    Option 3
    My preference would be to have all parts in the case and not mounted to the door - Is there enough room to mount the powers supply on its side? Might give more room/options?
    http://literature.rockwellautomation...m001_-en-p.pdf
    This document makes an interesting read if you want to focus on handling electrical noise in a system (thanks EddyCurrent!)
    Jim
  3. The Following User Says Thank You to cncJim For This Useful Post:
    Hi Jim,
    Thanks for the quick reply.
    I did look at mounting the power supply veritally but the lock on the door hits the top of the PSU on one side and on the other there is a bar which sticks proud of the door panel visible in the second picture next to the gounding wire, which also hits the top of the PSU meaning I have to move the PSU more to the centre of the case.
    Besides, being lazy I wanted it flat so I can easily access the screw terinals
    Dave
  5. #4
    Thanks Jim,
    I just remeasured and the lip on the door clears the PSU by 1mm.
    Looks like your suggestion is the better one and it does give me a lot more space. I origanlly wanted to keep the PSU flat for ease of access to the screw terminal but I can live with it this way, how many times should I need to access these anyway, famous last words.
    Dave.
  6. #5
    Have you thought about safety relay, estop, fuses etc
  7. #6
    I bought a EMI Panel Mount IEC Filter 10A from cnc4you to plug the power lead into thinking it was fused, just checked and its not.
    I have a red panic button and proximity sensors for the estops.
    Not sure what you mean by safety relay
  8. #7
    Safety relay, I get it now. I hadn't thought that deepely about it, I assumed the estop and circuit breaker would be good enough.
  1. Advice on a charge controller please :)
    By blackburn mark in forum General Electronics
    Last Post: 04-05-2020, 07:28 PM
  2. Replies: 0
    Last Post: 13-12-2015, 08:22 PM
  3. USB/Ethernet controller for Mach3/4 advice
    By paulus.v in forum Control Hardware & Systems
    Last Post: 17-02-2015, 09:37 PM
  4. Advice please! JAF Motion Controller issues!
    By Mark Chard in forum Machine Control Software
    Last Post: 31-01-2014, 05:03 PM
  5. Which controller and motors? Newbie advice please
    By Nealieboyee in forum Motor Drivers & Controllers
    Last Post: 16-10-2012, 02:56 PM
