    Hi there
    I've got generator module and stepper driver connected with two power source 24v(driver) and 5v(generator) like in the picture
    I use PUL-, DIR-, and ENB-, 3 cables connected to the M542 driver
    In this setup I should join all pluses together and connect to common anode(+)
    I do not why but everything works without this cable - common anode(+).
    I am confuse here. I send only positive signals to the module
    I can change direction of the motor (DIR) and switch on/off the motor (ENA)
    Not the same situation if I use only PUL+ DIR+ ENB + without common cathode this time(-).
    Without common cathode I can only run one direction (like having only PUL+ and (-)cathode or PUL- and (+)anode two cables connected)
    I can have on/off function (ENA, because module send HI signal and disable(off) the driver.
    I know that signal I get is PWM square wave, multimeter allows to check polarity of such a signal (all + or -)
    Can anyone explain how this works please, many should benefit too.
    System got all function start/stops using ENA and Direction using DIR all done by 3 cable connected to (-) without having common anode(+)
    Tom
  1. How do I wire a stepper driver to a stepper motor?
    By swood1 in forum Stepper & Servo Motors
    Last Post: 21-09-2014, 05:40 PM
  2. Replies: 1
  3. Running a three phase router/mill on a generator?
    By gavztheouch in forum General Electronics
    Last Post: 19-02-2013, 12:39 PM
  4. WANTED: stepper driver module
    By tinshak in forum Items Wanted
    Last Post: 16-01-2013, 09:31 AM
  5. Stepper motor as a generator??
    By wiatroda in forum General Discussion
    Last Post: 08-08-2011, 10:17 PM
