Thread: Isel CPM 3020 - run with mach3?
It depends, a colleague have a Isel machine, this part have DC-Servos with +/-10V. He must only change the controller (BOB) to run it with LCNC.
If your machine have the same parts, then you can change the controller with an analog controller like Mesa 7i77, CSMIO IP/A, Peco.
If you have stepper drives then probably, the are controlled via Step/dir.
In this case a simple BOB is enough.
Eventually you can tst this SW for the Isel.
http://www.spline.nl/machines/kay.htmlLast edited by uli12us; 11-01-2016 at 12:27 PM.
11-01-2016 #2
Thank you for your reply. The CPM 3020 uses stepper motors so will the current drivers run with mach3? I guess I`ll just have to identify the step and direction inputs and connect accordingly from the BOB. I realise that I actually need to wait for the machine to arrive and then I can take pictures and post them up here.
I would like to use KAY but it expensive. I have a little knowledge of cnc from when I used Mach3 on a TEP but I`m not clear what original software would run the machine.
It would be good to run the machine off the original software to see if it works and then upgrade it to run off mach3 but seems silly wasting money.
11-01-2016 #3
Because you have stepper motors and drives, the only part you need, except Mach3 will be a rather simple bob. But try first Kay, maybe its good to handle.
Mach3 itself costs as much, but you don't need to rewire anything in the machine. But I don't know which stepper drivers are used in the machine.
I believe every drive can be controlled via step/dir maybe with 12V instead of 5 or with negative logic, but that all isn't really complicated.
11-01-2016 #4
Anyone got any recommendations as to a good breakout board - links if possible. There are so many suppliers. I appreciate and will purchase based on the advice.
I am familiar with mach3 to some extent and so I think if I can run the machine with it I will. I'd at least try KAY or Galaad to get it moving directly without any effort which would be amazing but quite costly for only a test.
chris
11-01-2016 #5
13-01-2016 #6
Evening guys
well the machine arrived today. It does power up in as much as the door light comes on (but the door wouldn't open, I had to unscrew the handle to open it) and you can turn the motor on, you can see the motor relay engage but the motor doesn't kick in but I guess this is controlled from the software.
Anyway, the huge important bit which I'm dying to get your advice on, the electronics.
to my dissapointment, it's an all in one board and all the axis plug into it. The picture is very big, sorry, I will resize asap but I'm on my iPad and it's late
Same image here as it seems to be flipping it upside down on the forum: http://raynerd.co.uk/wp-content/upLoads/image.jpeg
i guess the electronics and large transformed on the right is for the motor or is that simply the PSU for the entire machine.
Does it looks like I've any chance of running with mach3 or do I need to strip the board and start fresh with new drivers. I'd be confident in retrofitting 3 fresh drivers and to be honest, I'd probably have to manually turn on and off the spindle motor via a switch to start with. Consequently, I'd pretty much rip out all the electronics. If I was to do this, is it entirely certain the motors would be ok or would these need swapping, in which case the project has just got massive as it would require a full strip down of the entire machine and not just the electronics panel.
Ill stop woffling. I really look forward to your replies guys.
ThanksLast edited by craynerd; 13-01-2016 at 12:58 AM.
13-01-2016 #7
Cant see anything that would stop you converting the boards to the typical motion controller+ Breakout board + motor drivers. But we will still need to see the motors, hopefully they are compatible with the standard types of stepper motors ( good reading on here: https://learn.adafruit.com/downloads...per-motors.pdf)
I would keep the powersupply and reuse the safety equipment then stick a motion control board and either a leadshine MX4660 or a gecko G540.https://emvioeng.com
Vevor 3020 cnc Autolevelling
By iBeta in forum Machine DiscussionReplies: 8Last Post: 22-11-2015, 07:08 PM -
DIY 3020 CNC I/O Board
By Pointy in forum Electronic Project BuildingReplies: 10Last Post: 27-07-2015, 10:48 PM -
NCStudio to Mach3 question for a chinese 3020 router
By Fivetide in forum Chinese MachinesReplies: 3Last Post: 11-04-2015, 10:37 PM -
is a cnc 3020 right for the jobs i need doing
By RsvRcarl in forum Milling Machines, Builds & ConversionsReplies: 3Last Post: 28-03-2012, 01:34 AM -
Improving your CNC3040/3020
By DanielF in forum Motor Drivers & ControllersReplies: 0Last Post: 22-11-2011, 01:48 PM
