Page 6 of 9 FirstFirst ... 45678 ... LastLast
  1. #51
    Quote Originally Posted by valdis034 View Post
    Which spindle bracket is better? Thinking if they will have the same strenght?
    This one:
    http://www.ebay.co.uk/itm/Dia-80mm-S...3D322225414288
    or this one
    http://www.ebay.co.uk/itm/80mm-Diame...3D322225414288
    The second link/item is the one to go for.
    .Me
  2. #52
    This one:
    or this one
    Definitely the second one, but beware, even that can crack.
    http://adapting-camera.blogspot.se/2016/09/cnc-upgrade-progress-disaster-strikes.html
    This is how I fixed it:
    http://adapting-camera.blogspot.se/2...g-cracked.html
    Anyway, I bought a new one but have not installed it yet and I think the quality is the same. Cast aluminum, at least the way these cheap brackets are made, are not the best for this purpose.
  3. #53
    I'd buy a SBR50UU and use the housing as it's 80mm and slit along one side to clamp the spindle....
    Neil...
    Build log...here
  4. #54
    Thanks guys, placed an order for second option. We will see how it will hold.
    Today got my spindle and was surprised to find 3pin plug for it. Isnt it supposed to be 4pins ( three phases and earth)?
    Another thing the locking nut has been drilled, is that they way they tried to balance it? Is it normal?
    Isiųsta naudojantis SM-G900F Tapatalk 4 Lt
  5. #55
    exactly the same as mine.
    yes the drill holes are their attempt at balancing the lock nut.
    Mine only has three pins - i connected the earth ground to the shell of the plug and tested for connectivity to the body, the whole machine is earthed anyway and the motor has a metal body so should be safe enough.
  6. #56
    Off course with spindle got the inverter and have the electrical box, thinking that box might be a bit small for all the stuff..
    what size enclosures you have to fit everything?
    Here will be 4 drivers, BOB, toroidal transformer, 24v supply, realays, filtered fan on the door or on the side of the box and some wires..
  7. #57
    going to be tight i think, i like a bit more room - makes setting up/debugging/repairs easier IMHO.
  8. #58
    I've got a 600 x 600 panel and its tight enough without the vfd in there....
    Neil...
    Build log...here
  9. #59
    This one is only 600380. So yes, need to look for something bigger.
  10. #60
    I always tell people to get a 6x9...some listen...some dont.
    .Me
  1. Aluminium Profile
    By amxen in forum Metalwork Discussion
    Last Post: 13-08-2015, 07:37 PM
  2. eBay: KB Aluminium Profile Supplies
    By KB Aluminium in forum Items On eBay UK
    Last Post: 20-05-2015, 03:46 PM
  3. aluminium profile for cutting bed of router
  4. Aluminium Profile - ValuFrame?
    By Tenson in forum Marketplace Discussion
    Last Post: 28-06-2012, 02:20 PM
  5. Tapping Aluminium profile
    By jonbabbz in forum Tool & Tooling Technology
    Last Post: 28-05-2012, 08:09 AM
