    I recently aquired a new mini lathe (7x14) and have been unable to align the tailstock (new type with 4 grub screws).
    Tom suggested I check the headstock alignment.
    Any suggestions on how to do this:question:
    Ed
    Tom's Avatar
    Location unknown. Last Activity: 30-11-2016 Has been a member for 7-8 years. Has a total post count of 172. Referred 1 members to the community.
    Hi Ed,
    Sorry for the delay. This is the method I used. Probably frowned upon by proper machinists, but this is just a hobby, and it seems to work.
    http://www.gadgetbuilder.com/Lathe_Align.html
    First up just measure what you've got (mine wasn't great, vertically I had 0.13mm error over 190mm distance). Actually changing the alignment of the spindle can be done with shims (foil, drinks cans, etc) under various corners of the headstock casting. Getting access to the appropriate screws means you have to remove (or loosen at least loosen) the electronics box, motor, changegears, and leadscrew.
    It's a bit of a faff, but taught me lots (like the fact the torque on the screws can affect the readings). End result is that vertical alignment is now ~0.01mm over 190mm, and horizontal alignment is better than I can measure.
  3. Quote Originally Posted by pequod View Post
    Ed
    Google is your friend.... here is a selection...
    http://www.wrathall.com/Interests/ma...20accuracy.pdf (old and general but useful - I used this on my old-timer)
    http://www.mini-lathe.com/Mini_lathe/Tuning/tuning.htm
  1. Mini Lathe Part
    By fragger6662000 in forum Milling Machines, Builds & Conversions
    Last Post: 15-11-2011, 06:13 PM
  2. FOR SALE: Sieg C3 Mini Lathe
    By Jonathan in forum Items For Sale
    Last Post: 07-05-2011, 05:19 PM
  3. Mini CNC lathe builders
    By GeorgeD in forum Lathes, Lathe Rebuilding & Conversions
    Last Post: 28-07-2010, 09:00 AM
  4. A Mini Lathe
    By irving2008 in forum Milling Machines, Builds & Conversions
    Last Post: 03-05-2010, 03:11 PM
  5. WANTED: SIEG C3 Mini Lathe
    By derekm in forum Items Wanted
    Last Post: 07-04-2010, 07:35 PM
