Thread: Slave axis help
24-01-2016 #11
Looking at the pictures you have direct drive and massive pinion size. This will cause you troubles. First the large pinion will give huge pitch size so resolution will be very low.
Worse is the affect of the direct drive with no reduction. You'll struggle with torque and Resonance will be high which could affect motors. The digital drives will help but still your upping there work load which isn't good.
My suggestion is to put minimum 3:1 Reduction using Timing belts/pulleys. This will give more torque better resolution and lower resonance. If not your going to struggle with all those things.!
CSMIO/IP-M and slave axis functionality
By Neale in forum CS-Lab (CSMIO)Replies: 24Last Post: 29-01-2019, 10:33 PM -
Slaved axis, 2 steppers on Y axis with a PLC4x-G2 ? what about the XP23 connector ?
By pierantoine in forum General ElectronicsReplies: 9Last Post: 23-05-2015, 02:07 PM -
Home Switches & Slave Axis in Mach 3
By Tenson in forum Artsoft Mach (3 & 4)Replies: 14Last Post: 03-03-2014, 11:43 PM -
NEW MEMBER: Goal - Enable 3-Axis CNC Bed Mill to Perform 5-Axis Milling
By LoveLearn in forum New Member IntroductionsReplies: 2Last Post: 25-01-2012, 08:46 PM -
Precision metal processing (3 axis, 5 axis, 7 axis) OEM
By 7AxisCNC in forum Manufacturer NewsReplies: 0Last Post: 17-05-2011, 02:04 PM
