    Hi eveyone. Quick q: how do you know when your laser bulb needs replacing. Mine has literally just stopped working. Its pretty dirty looking. Any other clues?
    Dirty? Got green algae living in the tube? If so then you will need to replace it. The water you run through the tube must be deionised and also have a bit of antifreeze for good measure.
    You can try flushing through with bleach but chances are the tube is toast.
    When a tube dies, it usually makes a fizzing sound like it is losing air, the intensity is dramatically reduced and finally stops working.
    https://www.youtube.com/watch?v=_UyqTSe0tMs
    https://emvioeng.com
  1. Replacement Boxford 160 chuck
    By Saracen in forum Boxford Lathes
    Last Post: 21-01-2016, 05:53 PM
  2. Replacement Part Required.
    By wildfowler54 in forum Bridgeport Milling Machines
    Last Post: 06-01-2016, 07:42 PM
  3. Replacement brushes needed for Champion 20v (BF20 clone)
    By davegrennan in forum Milling Machines, Builds & Conversions
    Last Post: 15-07-2015, 09:54 PM
  4. Hi replacement moons motor driver sr4h
    By cockneyrebel in forum General Discussion
    Last Post: 24-02-2015, 02:41 PM
  5. Romi EZ-Path S Lathe crt replacement
    By Nemo1966 in forum Monitors
    Last Post: 07-10-2013, 03:25 PM
