    A bit of a desperate plea for help I'm afraid... Does anyone know of any hobby laser support / setup people in Kent UK? I'm located in Dover Kent.
    The issue I have is mirror alignment. After spending hours over a number of weeks I just can not seem to complete this simple task. Each of my many attempts has just ended up with me sobbing in the corner. I'm at the point where I need help and happy to pay for someone's time.
    It's a Shenhui SH-350 (50W Chinese laser).
    When I originally receved the machine it worked out of the box but after an hour or so of firing it stopped working. The vender sent me a new power supply and tube which I fitted (it turned out to be a faulty PSU) and the machine is firing fine again but I cannot nail the alignment.
    I've watched a myriad of videos and read loads of articles around the subject and been though a number of rolls of masking tape but I just can get it right.
    Many thanks,
    Paul
    Similar Threads:
    Hi Paul,
    bit out of the way for me to come have a look but I have the same machine as you, I think. Did my alignments recently again too to make sure it was good. What seem to be the issues that you are actually having? Is the spot on each mirror not central? do you have differing intensity/focus with travel?
    I find that if I am not getting good results it is usually warped wood being cut or dirty lenses. May not be your case but do give the optics a clean.
    so let us know what happens and I will try and help you.
    https://emvioeng.com
    Thanks for the reply.
    To be honest I’m pretty sure it’s user error!
    It’s difficult to get the laser tube central on the first mirror (to high) then I just can’t seem to get the beam parallel on the second mirror with at least 5mm or so movement at each extremity of Y axis travel.
    Any advice would be appreciated.
    Ivery aligned a few lasers in my time ;-)
    Very impressive! I assume you don’t live near Dover ;) Unfortunately your picture serves to make me look even more inept!
    Im in essex so three if not more hours away, sorry
  1. Denford Easiturn 3 spindle alignment
    By Nemo1966 in forum Denford Lathes
    Last Post: 13-05-2020, 10:28 AM
  2. Boxford TCL 160 tool alignment
    By Saracen in forum Boxford Lathes
    Last Post: 05-11-2014, 10:28 PM
  3. Assembling & alignment precision concerns
    By njcook in forum Gantry/Router Machines & Building
    Last Post: 17-08-2013, 05:19 PM
  4. bearing mount, alignment and anything related
    By dsc in forum Linear & Rotary Motion
    Last Post: 31-10-2012, 02:29 PM
  5. Mini Lathe alignment
    By pequod in forum Lathes, Lathe Rebuilding & Conversions
    Last Post: 29-06-2009, 06:40 PM
