Thread: 3D Soap Dish
01-04-2018 #1
Hi all,
Heh - this isn't the first soap dish I've made and I doubt it'll be the last, but after seeing an abysmal design the other day (honestly, how can anyone make a soap-dish that doesn't work properly..?!) I thought I'd model one and cut it as a 3D object. The idea was that the ribs would droop in the middle so as to cradle the soap, whilst the troughs were to drop away at the edges to facilitate draining.
A couple of in-progress pics below. I've made it from a scrap piece of Sycamore I got given a while back. Still needs a bit of sanding and then a couple of coats of varnish. I've modified my CAM files since the first cut (for speed and efficiency) and I may make a special in African Black Wood. It'll be a nice prezzie for someone at some point..!
Wal.Last edited by Wal; 03-04-2018 at 10:36 PM.
The Following User Says Thank You to Wal For This Useful Post:
01-04-2018 #2
Il'l try this on a bit of sycamore I have, might even use a bit of zabrani I have been saving for years.
Can you give a clue to the cutter you used
01-04-2018 #3
Sure - I used a 4mm square end mill for the roughing and a 4mm ball nose for the finishing. In all honesty a 3mm would be better for the finishing pass, but you'd need a long neck/flute or a shaft no thicker than 3mm to avoid rubbing on the steep sides... I may flare out the troughs and the front and rear faces a bit on the newer model to make it a bit easier to cut...
Wal.
Sent from my HTC One M9 using Tapatalk
Wal I think you have too much time on your hands
02-04-2018 #5
Don't you mean my impeccably clean hands, Clive..?! ;)
Wal.
EDIT: To be honest, whilst seeming a bit self-indulgent, there's a fair bit I'm picking up with regards to how VCarve handles 3D objects - specifically how it cuts 'em. i.e. cutting along the troughs is A LOT quicker, but frustratingly if the 0.3mm step-over falls on an area that it's not allowed to get to the bottom of, it just ignores the bit that hasn't been cut - of course, you can get around it by narrowing the step-over or adjusting the raster angle - both of which increase cutting time, but them's the breaks, I guess. As a side note, I ended up going with a 45° raster angle, which gave me a decent enough finish in the troughs but wasn't ideal on the steep sides - using the 45° angle stressed the tool a fair bit too - leading to this:
02-04-2018 #6
02-04-2018 #7
03-04-2018 #8
04-04-2018 #9
Nice one John - can't wait to see 'em lacquered up! The figuring on the one on the left looks ace.
Wal.
04-04-2018 #10
Left one, right one needs a bit of filling of exposed wormholes
Attachment 24029Last edited by johnsattuk; 04-04-2018 at 09:51 AM.
