    My cyclone has a 125mm Pratt burnard 3 jaw chuck, just wondered if it is possible to mount a 160mm chuck. Obviously will need to machine a larger adapter plate.
    Thought that I had read somewhere the maximum chuck size for a cyclone was 150mm but can't find any info now.
    Stick a small bar in the chuck and measure the height over the bed and the height over the cross slide, factor in jaw protrusion for larger work and you can calculate the maximum chuck size that will fit the machine and your work requirements.
    Since I converted to a headstock with integral ER40 collet chuck on my manual lathe I only use chucks for rough and odd shaped work and round that's over 30mm OD. A collet chuck has the additional advantages of concentricity, short Z length and small OD relative to work holding capacity,
    - Nick
  1. Altivar inverter - setting maximum speed
    By JohnHaine in forum Motor Drivers & Controllers
    Last Post: 06-01-2015, 08:12 PM
  2. maximum deflection - sanity check
    By dsc in forum Gantry/Router Machines & Building
    Last Post: 11-02-2013, 08:33 AM
  3. Maximum size of box section, Stacking box section, Construction Angle
    By andy586 in forum Gantry/Router Machines & Building
    Last Post: 01-02-2013, 04:29 PM
  4. Stepper shaft size and pulley bore size problem
    Last Post: 15-06-2010, 03:11 PM
  5. maximum amps
    By petejw in forum General Electronics
    Last Post: 11-08-2009, 10:40 PM
