Thread: Small CNC Router
21-02-2016 #1
Hi Tom,
What do you want to cut with it? I'm hoping soft materials like expanded polystyrene or carving foam (based on the high Z)?
Whilst it's great to welcome someone else to the CNC club as it is a great hobby, the design is fairly weak and would vibrate a lot with anything tougher like wood.
Unsupported rails, high gantry sides, very thin Z axis rails, very long reach Z axis all contribute to the low stiffness. Is the base actually transparent (plastic) or is that the render? I think unless this is for very light duty I would not go down this route. Have a look at the build logs on this forum for more substantial machines.Last edited by routercnc; 21-02-2016 at 09:19 PM.
21-02-2016 #3
21-02-2016 #4
Appreciated guys! I'll research for a while and come back with a new and improved rev2! Watch this space...
22-02-2016 #5
It would help to know what you plan to cut, especially in terms of the hardest material and the height you will want the Z to go. Remember that the higher you go with the Z the more extension you will need cutting materials near the bed, so the gantry will flex more.
Best of luck.
Rob
BUILD LOG: Small rigid router - Design advise needed
By mitchejc in forum DIY Router Build LogsReplies: 120Last Post: 17-06-2015, 08:12 AM -
Small indexable mills for router?
By Boyan Silyavski in forum Tool & Tooling TechnologyReplies: 6Last Post: 18-04-2015, 11:00 AM -
Small Gantry Router
By mike os in forum Gantry/Router Machines & BuildingReplies: 28Last Post: 08-01-2015, 07:02 PM -
WANTED: Wanted small cnc router
By lukecnc2012 in forum Items WantedReplies: 1Last Post: 10-10-2014, 06:51 PM -
Small desktop mill/router for cutting <=6mm aluminium
By matt-b2 in forum Marketplace DiscussionReplies: 2Last Post: 08-12-2013, 01:04 AM
