    kell's Avatar
    Lives in doncaster, United Kingdom. Last Activity: 05-08-2023 Has been a member for 9-10 years. Has a total post count of 53.
    I am using the linear command but it runs in the x direction on the part and i want it to run down the y direction.
    Hope im making my self clear.
    Lee Roberts's Avatar
    Lives in Wigan, United Kingdom. Current Activity: Viewing Moderator Control Panel Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 2,914. Received thanks 227 times, giving thanks to others 776 times. Made a monetary donation to the upkeep of the community. Referred 11 members to the community.
    Hi Kell,
    I think you need to go into the Linear Sketch Pattern Property Manager, once you setup and define "Direction 1/X-Axis" it should enable "Direction 2" and this will be your Y-Axis, to specify the Y direction for the Y-Axis, you first need to add additional "instances" for Direction 2.
    Let us know if that works for you :)
    .Me
    kell's Avatar
    Forgot to say I am using solidcam,
    Don't seem to be able to see a sketch pattern any where
    Quote Originally Posted by kell View Post
    The sketch pattern is something you would have drawn or already have in front of you to be working with?
    It's the the "property manager" for either I think you need in order to select or change the YAXIS direction.
    .Me
    kell's Avatar
    I see. Now sorted cheers
  1. Replies: 2
    Last Post: 07-12-2013, 04:13 PM
  2. NEW MEMBER: Hi,Friend,I'm a B2C seller from China for ballscrew,linear guide,linear shaft etc.
    By yvesleeok in forum New Member Introductions
    Last Post: 10-08-2013, 11:15 AM
  3. Solidworks help
    By D-man in forum Solidworks
    Last Post: 31-07-2013, 06:43 PM
  4. Solidworks help
    Last Post: 19-03-2013, 11:42 AM
  5. Replies: 0
    Last Post: 04-12-2011, 03:23 PM
