Thread: VFD choice
    Hey guys, I've got a spindle here which I would like to use on a new build, anyone recommend a decent cheap VFD to power it?
    Normal 240V VFD won't work derek you need 380V input to get 380V output so basicly you need 3 phase input. Then the VFD is just speed controller.
    There are 240V input 380V output VFD's but they are expensive and not very clean regards electrical noise. Also doubt you'll find one with 6.6Kw output.
    Cheers Dean, yeah I have 3 phase in our unit so that's not a problem.
    Do I really need to go to 6.6Kw? Would the 5.1 not be a better option?
    So in terms of speed controllers, if I have 3 phase in the unit, does that mean I only need a speed controller?
    Quote Originally Posted by D-man View Post
    Do I really need to got to 6.6Kw? Would the 5.1 not be a better option?
    So in terms of speed controllers, if I have 3 phase in the init, does that mean I only need a speed controller?
    Well kind of thou must be able to output 200hz to get full speed range. You'll be better with VFD but they won't be cheap and nearest will 5.5Kw.
    Ok mate cheers, thought I could of just done with a speed controller than a costly VFD.
    Lovely spindle too so smooth and it spins forever
    if this could do the job i reckon i could live with that. saves buying another spindle i guess
    http://www.ebay.co.uk/itm/5-5KW-380V...8AAOSwLVZVwLi7
    Yep perfect
    Good stuff!!!
  1. Beam choice
    By idegraaf in forum Gantry/Router Machines & Building
    Last Post: 22-03-2018, 06:38 PM
  2. Jazzcnc, the right choice in a custom made machine
    By alex wight in forum General Discussion
    Last Post: 18-10-2016, 06:39 PM
  3. CNC router choice out there.
    By CTJ in forum Machine Discussion
    Last Post: 10-12-2015, 08:51 PM
  4. Limit and Home Switch Choice
    By Wobblycogs in forum General Electronics
    Last Post: 02-12-2013, 05:16 PM
  5. Router/Spindle choice for Makita laminate trimmer upgrade
    By CraftyGeek in forum Makita Routers & Trimmers
    Last Post: 30-11-2009, 10:23 AM
