    this may be stupid but I cant figure this out how do you draw in metric measurement's in draft sight watched video s and cant get the setting right. Thanks for any help
    When you open a new drawing select the "standardgb" template, that's in metric.
    Neil...
    Build log...here
    So simple when you know how thank you very much
    Sent from my SM-G361F using Tapatalk
    Quote Originally Posted by whensparksfly View Post
    Yes but impossible when you don't!! No problems
    Neil...
    Build log...here
    I've been playing with it lot easyier now.how do you draw circle s in even spacing or in a exact place from each other
    If you want to draw a line of holes or a circle of holes you use the "pattern" command, either type it in at the bottom of the screen or on the right hand side there's a symbol of a cluster of 9 squares...
    Neil...
    Build log...here
    thanks I been getting on great with the pattern command.
    how do I Combine Shapes In Draftsight like a square with two circle ether end to make a slotted hole
    Draw your square and then snap a circle to the mid point of one side and click on a corner to set the diameter, do the same the other end and then use the trim tool to get rid of unwanted lines....
    Neil...
    Build log...here
  1. DraftSight hindering shutdown
    By cropwell in forum Computer Software
    Last Post: 07-11-2015, 11:50 PM
  2. Draftsight users
    By boldford in forum CAD & CAM Software
    Last Post: 24-07-2012, 02:25 PM
  3. DraftSight Callouts
    By matt-b2 in forum CAD & CAM Software
    Last Post: 17-02-2012, 12:57 PM
  4. Tutorials - From a drawing to a cutting example
    By luke11cnc in forum Computer Software
    Last Post: 25-09-2011, 10:19 PM
  5. drawing to g-code
    By ptjw7uk in forum Programmers Corner
    Last Post: 20-06-2009, 11:49 PM
