Page 5 of 6 FirstFirst ... 3456 LastLast
  1. #41
    Cheers lads! In my defence the end brackets were simply a temporary fix as I had run out of funds for more machining.
    So do you think this is the problem? Yeah I'm using Eding CNC software
  2. #42
    Ah now I remember playing with different mounting options!
    Back to the trading board!
  3. #43
    Ok so I found some scrap 25mm Ali and cut some end mounts out this shouldn't move!
    Loving these single flute bits from toolstoday.com
  4. #44
    Hows that going to help.?
  5. #45
    Hopefully moving the screw along and mounting end bracket to it? But what about the other end??
  6. #46
    I thought thicker the better and mounted on the end of the extrusion with 4 M12 bolts would keep it sturdy? The screw will be offered up to it and bolted to the plate
  7. #47
    Just make a bracket from 2 pieces of your 25mm plate and fit where your existing bracket is?
    Neil...
    Build log...here
  8. #48
    You mean a spacer between the two fixed peices
  9. #49
    No, I meant a bracket ;)
    Neil...
    Build log...here
  10. #50
    I dont know ...
    Derek, you know that ball screw should be under maximum tension right???? Not just fixed there to stay on place. And that means screwed both sides with lock nuts. I thought that was clear to you when decided on the rotating ball nut to move gantry.
  1. 50w laser - PSU issues?
    By calida in forum Laser Machines & Building
    Last Post: 09-02-2016, 03:25 PM
  2. Limit switch issues?!?
    By jonbabbz in forum General Electronics
    Last Post: 06-02-2014, 06:37 PM
  3. Calibration issues, advice needed
    By Kernow Jim in forum Motor Drivers & Controllers
    Last Post: 23-01-2014, 06:18 PM
  4. Page layout issues...
    Last Post: 09-08-2012, 07:10 PM
  5. Cable + Connector issues
    By tom3d in forum General Electronics
    Last Post: 09-01-2012, 06:56 PM
