Thread: Thor, or should that be Zeus?
14-06-2017 #331
Ye, ive been unlucky. Ive got 2 machines with native RS 232 ports as well as a USB one and PCI Express one. I cant get any of the 4 to work.
I need to do it again, but busy finishing Thor. If all goes to plan it might do some basic movement this weekend on all 3 axis.
14-06-2017 #332
I've got a cheap USB adapter, and have never had any problems. I did have to destroy the case to get it to directly fit onto the drives though.
Are you using the correct type of cable?
You'll need to check if it should be a straight through cable, or crossover cable (I would guess it should be a crossover for serial comms). Probably best to test the one you've already got, and then order the opposite.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
15-06-2017 #333
15-06-2017 #334
15-06-2017 #335
So what I've done is order a new F / M straight cable. The Kinco drive manual shows as default 2-2 3-3 and 7-7 wiring. Will try that first. Struggling to find (on Amazon) and null modem M / F cable in case.
Problem Ive had is that on my Panasonic drives that use Serial / proprietary, Ive also struggled to get it working.
15-06-2017 #336
I have a stack of about half a dozen HP DC7600 small form factor PC's that will shortly be going to the tip - you are welcome to all or any if you wish FOC. They have RS232 ports and multiple USB's - all have had their hard disks removed for security reasons - they are ex-corporate machines.
(the clear out continues !)
15-06-2017 #337
15-06-2017 #338
sweet jebus Chaz, don't do things by halves do you!
great work, look forward to seeing this thing in action
15-06-2017 #339
15-06-2017 #340
Hi Gary, would a USB to RS232 interface not suffer the same issues as standard USB when it comes to timing's? Or is there something I am missing here.
I also wonder if Linux is more reliable than windows (Especially when using USB) especially a Linuxcnc Live cd? I have no idea if you can get Mach 3 for Linux.
Chaz I'll be interested to see if it was a crossed cable causing your issues, fingers crossed for your weekend movements ;)http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
