Page 36 of 50 FirstFirst ... 26343536373846 ... LastLast
  1. #351
    Bad luck Chaz
    However I do seem to remember posting this about a week ago (post #283)
    "However my personal preference on big powerful machines is to have the home switches inside the boundries set by the limit switches, and have the limit switches trigger powering off of the drives. Also to have the limit switches within the boundries of mechanical stops that limit travel before ball screws over travel."
  2. The Following User Says Thank You to AndrewMawson For This Useful Post:
  3. #352
    Quote Originally Posted by AndrewMawson View Post
    Bad luck Chaz
    Hi Andrew, would a latched relay be suitable to perform the functions you describe?
  4. #353
    Chaz's Avatar
    Lives in Ickenham, West London, United Kingdom. Last Activity: 20 Hours Ago Has been a member for 5-6 years. Has a total post count of 1,242. Received thanks 91 times, giving thanks to others 60 times.
    Andrew, yes, point made. I thought of the same.
    Desertboy, fairly easily done with the CS Labs. It has sub 100ms error checking and can instantly disable the servos in a fault / trip condition.
  5. The Following User Says Thank You to Chaz For This Useful Post:
  6. #354
    I think the main point is to have a physical limit to save the ball screws if there is a runaway - preferably with a hard neoprene or other suitable plastic buffer.
    As for the latched relay then yes that's the easy way to do it, but it needs to be a fast acting relay.
  7. The Following User Says Thank You to AndrewMawson For This Useful Post:
  8. #355
    Chaz's Avatar
    Suppose this means it works.
    Speeds and Feeds
    24000 rpm - 6mm endmill
    Cutting Rate 4000mm/min
    Lead / Ramp at 1440 mm/min
    This was run at 80% speed. Overall happy with the cut considering there is no finish pass.
    DOC is 5mm, WOC is 1.2mm
    Still got more to do, but happy with the initial results.
  9. The Following User Says Thank You to Chaz For This Useful Post:
  10. #356
    Excellent - congratulations !
    BTW do you still want those Compac PC's ?
  11. #357
    Chaz's Avatar
    Please, ill make a plan to come and collect. Dont chuck them please.
  12. I haven't felt any disturbance in the force yet, I think you need to up the ante.
    Milling cutters start to perform around 3/4" diameter and up, anything less than that is squidgy
  13. #359
    Chaz's Avatar
    Agreed.
    Just did some test cuts, 10m/min with 10mm endmill. 0.5mm Stepover (wimpy, im still testing) and around 20mm of depth. The surface finish is superb.
  14. #360
    Chaz's Avatar
    Will do some more cutting tomorrow with 10mm endmill.
