Page 43 of 50 FirstFirst ... 334142434445 ... LastLast
  1. #421
    Having now seen Thor in real life I can tell you the pictures do not do it justice and then she moves and when she moves the earth moves with her lol.
    A true work of art
  2. The Following User Says Thank You to Desertboy For This Useful Post:
  3. #422
    Chaz's Avatar
    Yea I was going to suggest the RapidTurn unit to you as I also follow Cliffs channel, I would imagine your best bet would be to use some real hard stops you can then "bump" into for locating, as you say implementation on Thor is tricky because you dont want those fixtures to get in the way for other jobs.
    Thanks for taking the time to take and share the macro shots, its nice to see exactly what the finish is like from different machines.
    No problem, Ill do more of it as I do more machining and work out the good / bad / ugly of the machine's ability.
    The macro shot makes the part look fairly horrible however in reality, its not. Its 'as it comes' and can easily be polished up.
  4. #423
    Chaz's Avatar
    Does anyone know what NT30 spindle this guy might be referring to?
    http://www.cnczone.com/forums/uncate...uminium-4.html
    Impressive little machine ....
  5. #424
    That guy has his shit together ;)
    This bit I found interesting and I never considered but makes a lot of sense makes no difference to your machine though lol.
    "When you go with Chinese ballscrews, I think it is better to go with 5mm pitch, at least in my case as I dont need very fast rapids, due to force of the ball on screw. 10mm pitch screws will produce twice as much force on the wall of screw, and I wouldnt be surprised to see backlash even faster on 10mm pitch screws."
  6. #425
    Chaz's Avatar
    Some update pics of Thor. Need to finish the enclosure and 4th axis / lathe setup.Click image for larger version.
ID:	22346Click image for larger version.
ID:	22347Click image for larger version.
ID:	22348Click image for larger version.
ID:	22349Click image for larger version.
ID:	22350Click image for larger version.
  7. The Following User Says Thank You to Chaz For This Useful Post:
  8. #426
    Chaz's Avatar
    Does anyone know how to deal with dual probes, on NC and one NO, going into the same probe input?
    Can I run two probe inputs?
    This is the issue, how else to wire this (goes into CS Labs) input 3.
  9. #427
    you could use a relay on one output to get both of them to NO or NC
  10. The Following User Says Thank You to Desertboy For This Useful Post:
  11. #428
    I've been thinking about exactly this problem for my own machine (also using CSMIO). I haven't built the touch probe yet but I was intending to use a simple bit of circuitry to invert one of the signals and then combine them. I'm not sure that you can solve the problem without adding something outside the CSMIO as it only has one input that is suitable for the job.
  12. The Following User Says Thank You to Neale For This Useful Post:
  13. #429
    Lives in East Lothian, United Kingdom. Last Activity: 22 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 2,909. Received thanks 360 times, giving thanks to others 8 times.
    You need to invert the NC signal to NO, otherwise the probes will interfere with each other if run in parallel.
    My preference is to run probes NC, as then any circuit failure triggers a stop, but then you'd either need a switch to swap between probes, or wire them in series.
    Either would be possible with a transistor or two, and a couple resistors.
  14. #430
    Chaz's Avatar
    I emailed the probe vendor as the tip is not concentric. He responded with some info on how it can be calibrated. I then searched and found this - http://www.machsupport.com/forum/ind...c,17766.0.html - Whilst this doesnt fix the actual issue, it looks like I can use the same prob or perhaps two of them for different uses (I bought two as I was importing it from the US anyways). Perhaps next time I should pay attention to the other stuff in the box.
