    yeah...I think I got that one covered....
    Power 550W
    Distance between centres : 350mm
    Swing Over Bed: 180mm
    Swing Over Cross Slide: 110mm
    Taper: MT3
    Tailstock Taper: MT2
    Chuck diameter: 80mm
    Spindle Speed: 50 - 2500rpm
    Spindle Bore: 20mm
    Cross slide Travel: 65mm
    Chuck diameter 100mm (Integral spindle plate is 100mm no adapter plate required)
    Range of Metric Threads: 0.5 - 2.5mm.
    Range of Imperial Threads: 12 - 52 TPI.
    Spindle Accuracy: 0.01mm.
    Size with packaging is L: 81cm W: 30.5cm H: 31.5cm
    Operating instructions enclosed.
    American circuit board
    230v 50Hz motor
    Actual dimensions of lathe - 29in.x 10in.x 9 in.
    Net weight/Gross weight : 42/45Kg.
    I'll dismantle it to take it up into the loft!
    Having spent too long researching these over the past few days, I'd learnt that an independent 4 jaw was going to be the most useful, therefore I'll probably take the package & just flog the 3 jaw chuck on (most comments I've read suggest that you never go back to a 3 jaw after using an independent 4 jaw!).
    I genuinely don't know what size tooling it uses yet (I'm hopefully going to see these at his premises tomorrow)
    Here's my initial shoppinng list...
    the lathe ith independent 4 jaw chuck.
    tailstock chuck
    A cutting set! (was just going to go HSS as I have a grinder and read that it's easy to maintain these youirself)
    nice to haves...
    lever tailstock
    Quick change toolpost.
    proper boring rod.
    Quote Originally Posted by HankMcSpank View Post
    If you are worried about run out on your 3 jaw then get yourself a set of soft jaws for it and bore them out on the machine that it will be used on. I have done this many times before, its quick and easy to do.
    Just a thought....
    What a splendid idea....do these soft jaws cost much? (cos it may be cheaper just to buy a 4 jaw independent chuck!
    Perhaps I need to hold fire on this as there's stuff popping up that I'd never considered (& it's stuff that'll save me outlay!)
  5. #15
    Soft jaws should only be about 20-30 a set depending on the chuck manufacturer.
    They do have more uses than just boring out the inside diameter to prevent runout, you can also bore out the face's with a shoulder for holding larger dia items. Say you had a 100mm dia circular bearing holder with a finish width of 20mm then you could bore the jaws at 100mm dia down to a depth of say 15mm, cut the 100 mm dia material a couple of mm's oversize in a saw and then when you put it in the chuck and tap it up to the shoulder it will run true and will be easy to get the width parallel.
    Also if you bore them to the size of the part you are machining then it helps prevent marking of the workpiece that hard jaws can sometimes leave, specially on soft material like aluminum.
  6. #16
    Quote Originally Posted by Kip View Post
    If you're using 10mm tooling I have a "gret handful" of brazed carbide tooling (new) you can have as I never use it.
    Wow, what a kind offfer, I'm starting from zip .....I'd like to take you up on that if the lathe turns out to take 10mm tools - thanks! (these will no doubt weigh a little bit...obviously I'll pay the postage!)
    I'll let you know later!
    You'll get a flavour for why I need a lathe from this set of photos, I've just completed this -
    (those lines are on the lower surface - top is nice & smooth. That centre circle looks a little odd as I haven't come all the way through to the top surface with it . - also those little holes are meant to be different - there are two sizes of DIY pickups I need to mount, both of which have different pole spacings)
    The cheapest/quickest traversing pickup winder I can dream up....
    "What I learnt today" - biggish circular stuff is painful to do on a mill and doesn't look so neat after either!
    (& I dare say not that 'true' either!)
  7. #17
    But did you leave a little bit for finishing? A lot of the things I make I don't bother with a finishing pass as it's more a functional than aesthetically pleasing thing.....I just bought an Alimaster milling cutter made by Mitsubishi....just to see if it's better than the Alu Power I got given to try....Amazing finish by comparison to an old Hydra Al cutter....With a finishing pass it left a mirror finish!
    Oops pressed the thanks button there by accident - have one anyway (for the offer of the tools!)
    No I didn't use a finishing pass...1. becuase I've never used them (!) & 2. I've not bothered to work out how finishing passes would slot into my workflow!
    This was just to get a cheap & dirty coil winder wheel in situ PDQ.
  8. #18
    Couldn't get over there today (it's further than I thought & this is London!).
    Called the seller - it seems it does take 10mm tools ....Kip I'll PM you!
  9. Quote Originally Posted by HankMcSpank View Post
    To do circular stuff in a mill, mount the workpiece on the spindle and clamp the lathe tool(s) to the bed using a vice or purpose-made jig.
    See [ame="http://www.youtube.com/watch?v=wbfXXeiSHsw"]YouTube - Taig mill turning bushings[/ame] as an example
  10. #20
    Tom's Avatar
    Location unknown. Last Activity: 30-11-2016 Has been a member for 7-8 years. Has a total post count of 172. Referred 1 members to the community.
    Hank,
    If you go the 4 jaw independent route, consider getting a larger chuck than standard. Standard is 75mm.
    100mm and 125mm are both options. 125mm uses up a fair bit of bed length, but i've found myself boring holes in sheet that I wouldn't have been able to hold in a 100mm chuck. Also the large spinning mass has smoothed some of my cuts out (not to mention making the lathe significantly more DEADLY :twisted:)
  1. Mach Turn
    By Kai in forum CAD & CAM Software
    Last Post: 02-08-2016, 01:40 PM
  2. 11 hours of trying to get the motors to turn, help please
    By Wotsit in forum Stepper & Servo Motors
    Last Post: 05-02-2013, 02:07 AM
  3. LED not turn on
    By Awel in forum Motor Drivers & Controllers
    Last Post: 06-12-2011, 05:59 AM
  4. Sieg Mini lathe - smallest diameter rod turn-able?
    By HankMcSpank in forum Milling Machines, Builds & Conversions
    Last Post: 18-11-2010, 12:15 PM
  5. Mini Lathes and their capability
    By GeorgeD in forum Lathes, Lathe Rebuilding & Conversions
    Last Post: 02-08-2010, 04:29 PM
