Page 1 of 3 123 LastLast
    It's getting to the point now where I have to admit defeat & seriously consider shelling out for a mini lathe (her indoors isn't going to see the funny side of this one at all).
    To justify the purchase to myself, I need to be convinced that it is possible to turn Stailness A2 rod.
    i'm talking here, skimming (is that the right term?!) 2mm off M10 diameter ...to a length of about 20mm.
    Someof the more recent mini lathes have decent sized motors (by mini lathe standards).
    here's one at 400W I'm thinking about....
    http://cgi.ebay.co.uk/Mini-Lathe-Bra...lenotsupported
    or a slightly larger model for £50 more...
    In the main, I'll likely only be turning acrylic, aluminium & perhaps a bit of brass ...but just wanted to know if stainless is do-able in small bite size chunks approach?!
    Hank
    If all you want to do is turn small pieces i would consider second hand. Save yourself a fortune. i have a tiny unitmat that will only take up to 20mm in the chuck that does well enough. Decent cutters and cooling (bucket, small bore hose and a windscreen washer motor with sponge over the end) is priority. The lathe you see there is the same as clarke, axminster and sealey in the same clothing. I must admit i do have a bigger lathe but by the time you buy all the other tools to go with it-----phew fortune blown.
    Quote Originally Posted by 2e0poz View Post
    Hank
    The problem is that I need to turn up to 3"-4" lumps of acrylic...so I do need the larger chuck size.
    Have you a pic of that cooling system? I'm curious how the sponge fits into the equation (what's its purpose)
    Quote Originally Posted by HankMcSpank View Post
    Filter, goes over the pump pickup.
    Sounds overkill to me on a small lathe, ran one for years with nothing but a coffee can and a paint brush, at least you get it where you need it which isn't in your boots :heehee:
    John S -
    Quote Originally Posted by Kip View Post
    .tip's are expensive at around £18 for 10.
    That's cheap, not expensive, some of mine are nearly £10 per tip and only one cutting edge.
    John S -
    Hank i wish had one to show you as it was only a suggestion to improvise. Like John said it is to stop cutting being sucked back up. We have a chap here in Swindon selling a lathe for £150 from his business workshop, sounds great till you see it. Its huge and would require a forklift to shift it and no room for that???? One place people forget for cheap secondhand are the papers like 'Loot'. Hope you find one for the right price.
    Tom's Avatar
    Lives in Nottingham, United Kingdom. Last Activity: 11-11-2023 Has been a member for 9-10 years. Has a total post count of 176. Referred 1 members to the community.
    Hank,
    Either of those lathes are the ones to go for (i'd go for the larger motor). They're a different manufacturer that the Axminster, Chester, Clarke, etc.
    Differences (improvements) over the Chester, etc include:
    Heat treated ways (if you believe the sticker)
    Rectangular saddle (Chester etc has rough-cast "H" shaped saddle)
    Way oilers in saddle
    Way wipers
    More powerful motor
    I have a 4yr old Chester, and would buy the one you've linked to next time.
    I've never cut stainless, but it work hardens so you need to take as big a bite as you can each time. I've turned 5inch diameter alu before (bolted directly to the spindle face), so they're pretty flexible. Motor power would be a problem if you tried steel in the same diameter.
    It almost certainly won't cut stainless "out of the box". I was very disappointed with my lathe to begin with. I even struggled with (small diameter) steel until I'd done a fair bit of adjustment. With a sharp bit now though I can take 2mm off a steel diameter without too much bother (I changed the spindle bearings to taper rollers before doing this). They're great lathes as long as you treat them as kits for finishing, rather than production-ready.
    Enjoy!
    Hi 2E0poz ...alas whatever I buy has to go through a loft hatch!
    Tom, thanks for the input - I think they're from the Real Bull factory in China (SPG tools is slioghtly cheaper, but out of stock for a week or two ...plus he's in the Midlands whereas this seller I linked to is only 20 mins drive away here in London.
    The seller has been very clever with the lathe price points.
    Yes The £340 lather is the better buy, but he also does a lathe with some useful accessories deal for a sneaky £395 (http://cgi.ebay.co.uk/Mini-Lathe-Bra...lenotsupported) ....it can all end up getting a little more than I'd expected to pay!
    Having spent too long researching these over the past few days, I'd learnt that an independent 4 jaw was going to be the most useful, therefore I'll probably take the package & just flog the 3 jaw chuck on (most comments I've read suggest that you never go back to a 3 jaw after using an independent 4 jaw!).
    I genuinely don't know what size tooling it uses yet (I'm hopefully going to see these at his premises tomorrow)
    Here's my initial shoppinng list...
    the lathe ith independent 4 jaw chuck.
    tailstock chuck
    A cutting set! (was just going to go HSS as I have a grinder and read that it's easy to maintain these youirself)
    nice to haves...
    lever tailstock
    Quick change toolpost.
    proper boring rod.
    If you are worried about run out on your 3 jaw then get yourself a set of soft jaws for it and bore them out on the machine that it will be used on. I have done this many times before, its quick and easy to do.
    Just a thought....
  1. Mach Turn
    By Kai in forum CAD & CAM Software
    Last Post: 02-08-2016, 02:40 PM
  2. 11 hours of trying to get the motors to turn, help please
    By Wotsit in forum Stepper & Servo Motors
    Last Post: 05-02-2013, 03:07 AM
  3. LED not turn on
    By Awel in forum Motor Drivers & Controllers
    Last Post: 06-12-2011, 06:59 AM
  4. Sieg Mini lathe - smallest diameter rod turn-able?
    By HankMcSpank in forum Milling Machines, Builds & Conversions
    Last Post: 18-11-2010, 01:15 PM
  5. Mini Lathes and their capability
    By GeorgeD in forum Lathes, Lathe Rebuilding & Conversions
    Last Post: 02-08-2010, 05:29 PM
