Page 2 of 2 FirstFirst 12
    Ger21's Avatar
    Lives in Detroit, United States. Last Activity: 3 Hours Ago Has been a member for 5-6 years. Has a total post count of 563. Received thanks 77 times, giving thanks to others 0 times. Referred 1 members to the community.
    Thanks Clive, but I was hoping to find out why I could not do it,
    Because it's a REGION.
    Explode the REGION, and use PEDIT to Join the lines into a single polyline.
    Always save as V12 .dxf, for best compatibility.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
  2. The Following User Says Thank You to Ger21 For This Useful Post:
  3. #12
    Thanks Ger, I have sorted it now. I must admit to my ignorance in using AutoCAD. I need a good tutorial and the timeand brain energy to go through it.
    I am using AutoCAD from the '90's R14, so saving as anything other than a .dwg is not an option, and V12 is not in the export options list.
    BUT I did what you said (I suspected it was the REGION problem) and it worked after a couple of fumbling attempts.
    Cheers,
    Rob
  4. #13
    Ger21's Avatar
    I haven't used R14 since around 1999, but it should certainly save as R12 .dxf. Even current version still do.
    Try using File >Save As, and click on the drop down list for file type. R12 should be the last one?
    Gerry
  5. #14
    Sorry Gerry, but 'Save As' only give R14, R13 and R13 options as .dwg and the other option is a drawing template file .dwt.
    EXport works fine though and I now have created a .tap file from the drawing and am ready to do a test cut.
    Cheers,
    Rob
  6. #15
    Ger21's Avatar
    try typing DXFOUT in the command line.
    Gerry
  7. #16
    That works !
    I tried importing Corel to AutoCAD and it was exceedingly messy, Instead of lines and arcs I got some bizarre Bezier shapes the AutoCAD could barely understand and I did not like at all.
    Again with Coreldraw I have an old version and do not intend to waste money upgrading. It does not translate to .dxf at all well. It seems that all lines have thickness and that causes twice the gcode and a lot of unneccesary cutter movement. Also curves are 'blocky' or 'steppy', however you like to describe it.
    I have tried DraftSight, but that seems to be just a budget (free!) AutoCAD clone, nevertheless useful for what it is.
    Cheers,
    Rob
  8. #17
    The trouble with AutoCAD comes when you create a mesh. At point of creation you have to define how many facets the mesh will have and you cannot go back and edit. You have to redraw if you want to change it. Each ENTITY can have completely different facet settings and they do not SCALE well. If you can stick to lines, arcs and circles then everything is fine and dandy. You can project lines and arcs into 2.5D by changing their THICKNESS but for real 3D work you need Solid Works or the clone thereof. That will allow you to adjust the facet angle and size parameters on the fly when you export the finished shape. CorelDraw is not an engineering product and should not be treated as such, it is for making pretties. You should only use it when pretties and engineering collide, usually realising graphic art and making signage.
    I do like a good rant on Saturday morning, sets me up for the weekend. I shall go and blast 50 clays out of the sky with an antique muzzle loader tomorrow morning, bliss.
  9. #18
    Ger21's Avatar
    I doubt that you'll find many people modeling with old style meshes in AutoCAD in the last 10 years. Meshes definitely have their place, if you understand and know how to use them.
    But for the last 10 years, AutoCAD has become a very powerful 3D modeler, with a lot of new modeling features.
    Lofting, nurbs, mesh subdivision, smoothing, solids. I would say that you can do at least 90-95% of what Solidworks can do in AutoCAD, if you know what you're doing.
    THe biggest problem with 3D modeling in AutoCAD is that you need a pretty powerful PC if you're doing complex models. Until last year, I've done all my modeling in AutoCAD. But now I'm switching to Fusion 360, which is far more capable for 3D work, has built in CAM, and is about 15% of the price of AutoCAD. (And free for most hobbyists).
    But I still use AutoCAD for my 2D machining. AT least until I have time to learn more about Fusion's CAM.
    Gerry
  10. #19
    Have I opened Pandoras Can of Worms ?
  11. #20
    You need to buy an autocad R14 book, it just so happens.............
  1. a little more help needed
    By terry1956 in forum Motor Drivers & Controllers
    Last Post: 29-02-2016, 04:52 PM
  2. 3d AutoCad CNC machine parts.
    By jcb121 in forum Open Source Designs & Plans
    Last Post: 09-10-2014, 09:18 PM
  3. Replies: 8
    Last Post: 01-02-2014, 08:33 AM
  4. Concentric reducer in autocad
    By Web Goblin in forum Computer Software
    Last Post: 24-09-2012, 02:58 PM
  5. AutoCad 2007
    By D-man in forum CAD & CAM Software
    Last Post: 05-08-2012, 04:51 PM
