17-01-2017 #32
Not good idea unless you know they are isolated. It's little things like this that can easily introduce ground loops. I would remove the Gantry and Z axis earths and check again.
Also don't Earth the PC chassis to the Star point. This can cause all sorts of strange happenings. The PC PSU will have it's own path back to earth so adding another affectively creates G-loop.!
If all is correct regards Grounding etc and with good wiring practices then shouldn't be problem. I do this all the time and don't have any issues.
However it's always good idea to keep some seperation of high power/frequency cables like VFD or Mains voltage in respect Signal wires. Esp if the wire runs are long which guess may be on your machine.Last edited by JAZZCNC; 17-01-2017 at 08:54 PM.
BUILD LOG: New Build, Aluminium Frame Router/Mill
By Davek0974 in forum DIY Router Build LogsReplies: 101Last Post: 31-08-2016, 05:28 PM -
By Ricardoco in forum DIY Router Build LogsReplies: 6Last Post: 28-10-2012, 06:02 PM
