Page 6 of 9 FirstFirst ... 45678 ... LastLast
  1. #51
    Not related to interference but for safety - I was just looking at the 4th photo in post#1 ('dsc_0004.jpg') and noticed that the blue and brown cables going to the toroidal power supply appeared to be connected to incoming cables using male/female spade connectors. There looked like there was exposed metal on at least on of them.
    As they say, eyes like a sh#thouse rat. well spotted
  2. #52
    I think the connectors are not fully pushed together. There are other mains connectors fully exposed though, like on the SMPS's for 12v and 5v.
  3. #53
    So I unwired everything in the control box. Rewired separating power lines from control lines, and reducing enormously the amount of cables in there by chaining +5V and enable between the BOB and drivers. I now use 2 core shielded cable for the PUL/DIR signals. That made the wiring a heck more simple. Limits are not yet wired, homes neither, and the 24V PSU is not powered. Guess what ? Works like a charm !
    So now I'm going to move forward step by step, making sure that each increment does not cause noise to appear.
    Things look muuuuuuch neater now :) I'll keep you posted. As for the ferrites, I'll order some of them just as a safety.
  4. #54
    Ok sounds good don't forget the pics
  5. #55
    Quote Originally Posted by eurikain View Post
    Expalin or show this please because if what sounds like this is not good.?
  6. #56
    Hi Jazz,
    I hope he means that the enable (-) are being daisy chained from the enable terminal on the BoB and that separately he is daisychaining +5v on the BoB to step(+) dir(+) and enable(+) on each driver (chained on to the next driver and the next and the next). It'll work (Hmmmm ?) but I don't think I would do exactly that.
    Rob
  7. #57
    Rob is right. No worries, I meant "daisy chained". They each get 5V and the correct amount of amps. Same thing with the enable.
    Bad news, I introduced noise again, then rolled back to the state I was in when I posted my first message, and now the noise is not going away. Same thing, though much better than it used it be: in the first second of the spindle starting to turn, as well as the last second before it stops, the steppers move a few steps.
    I'll order a CSLab 4 axis motion controller today. Can anyone explain the following to me:
    - Zapp Automation sells it for 335 Euros (shipping included) => 0 in stock, have to wait 7-10 more days
    - CSLab sells it for 311 Euros (shipping included)
    So, obviously I'd go for CSLab official's website.. or does anyone have a spare one to sell ?
  8. #58
    You obviously have not rolled back fully. The questions are :-
    1. Is the noise coming from your VFD - which it very much seems to be.
    2. Is the propagation back along the mains cable or through the air
    The probability is a bit of both. Filters and shielding before spending money on a motion controller.
  9. #59
    I have, really, there's only the drivers, 5V and 70V PSU wired. The VFD is powered completely separately from the control cabinet. It's a different wall socket. Yes, it could be the mains. I need to call my local electronics store for help, I'm really lost now ^^. Can't deal with this myself.
  10. #60
    Does your building have an earth supplied by the electric company or do you use earth rods in the ground. Are you still using the plastic control box? Pictures would help.
    When you say the motors move a few steps when you turn on the vfd are they enabled and the motors locked when this happens?
  1. Noise, Interference, and unexplained electrical behaviour
    By g4ghp in forum General Electronics
    Last Post: 24-04-2014, 10:39 AM
  2. Bearing interference fit / press fit
    By Mad Professor in forum General Discussion
    Last Post: 30-09-2012, 10:26 PM
  3. 19inch Rack Enclosure - interference?
    By Washout in forum General Electronics
    Last Post: 22-09-2012, 08:10 PM
  4. Problem with X
    By gorbo in forum General Discussion
    Last Post: 24-02-2011, 04:33 AM
  5. Z Problem
    By airwolf in forum Machine Discussion
    Last Post: 10-11-2009, 07:08 AM
