14-03-2016 #1
Say,on Mach3, I start to route a pcb at say -0.1mm, and at some point want to lower the height by 0.01mm to give a total height of -0.11mm.
Is it as simple as entering 0.01 in the Z offset table? I tried, but it didn't seem to work.
15-03-2016 #2
That should work provided you are selecting the offset you are adjusting and your G-Code has no other overriding offset in it, if the code has an offset that will be selected by running the code,
- Nick
15-03-2016 #3
Yes it will work but Did you call new tool Offset from within your code just before the point you want the height change.? ie G43 H1 If not then it wont apply it.
solidoworks tapped thread depth and blind hole depth
By reefy86 in forum CAD & CAM SoftwareReplies: 2Last Post: 10-11-2015, 04:14 PM -
WANTED: Engraving Machine to engrave around 0.3mm depth, DXF files on aluminium, anyone?
By stuboy in forum Items WantedReplies: 0Last Post: 05-12-2013, 07:28 PM -
Trigonometry help please, plunge depth for a v cutter!
By cncJim in forum Tool & Tooling TechnologyReplies: 13Last Post: 06-11-2013, 03:41 PM -
Z axis not cutting to required depth
By dinasblu in forum Machine DiscussionReplies: 10Last Post: 02-07-2012, 05:38 PM -
End mill depth 'stop' rings
By HankMcSpank in forum Tool & Tooling TechnologyReplies: 10Last Post: 24-02-2010, 02:03 AM
