12-07-2016 #31
Hi Dave,
That used to happen to me a lot. Slot milling over 8mm risks poor chip evacuation and clogging of the tool. I've seen people machine the outside material completely away (i.e. an outer pocket to leave the central island, not a perimeter slot). But then you need to be able to hold the part in the middle which isn't always possible.
Another option is to use something like adaptive machining to mill a larger width slot than the tool.
I tend to reduce the DOC when over 8mm into a slot and that works OK. I vacuum out the slot on every pass and give a quick spray of WD40.
Beginner Moving Gantry Build? Read This!
By Tenson in forum Gantry/Router Machines & BuildingReplies: 3Last Post: 23-05-2018, 05:30 PM -
Garage CNC - A gantry style machine design
By fandango in forum Gantry/Router Machines & BuildingReplies: 14Last Post: 21-03-2014, 01:38 AM -
Truss style Gantry
By D.C. in forum Gantry/Router Machines & BuildingReplies: 28Last Post: 15-12-2012, 07:23 PM -
A few questions to start a DIY mini CNC
By purple_rob in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 03-08-2009, 11:08 PM -
Vertical moving gantry????
By Ross77 in forum Gantry/Router Machines & BuildingReplies: 9Last Post: 03-06-2009, 08:34 PM
