Thread: Limits problem
    I don't know if anyone can offer any advice, but all of a sudden and for no apparent reason (?) my limits were all triggered and would not reset. All ++ are on one circuit and all -- are on another. I also have a limits override switch. No matter how Mach3 was set up one or t'other of the limits was triggered. I use a second BoB on LPT2 and was beginning to suspect the BoB, cable or port card as everything looked hunky dory on the meter.
    So I changed the BoB and cable, but no joy - everything was the same.
    On an off chance I looked at all the other input pins and down the list, all the jog inputs were set as active on port 0.
    I de-activated them and the limits now behave as they should.
    Anybody know why ?
    Cheers, (Red Wine !!!)
    Rob
    Clive S's Avatar
    Lives in Marple Stockport, United Kingdom. Last Activity: 15 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,345. Received thanks 618 times, giving thanks to others 83 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Rob
    (Red Wine !!!)
    funny things can happen when you go down that road. Are you saying that when you put the ports back to 1 it is all working again.
    No Clive, it was red wine not port (or sherry !)
    The inputs were set as active, but on port 0. I just deactivated them (the red cross came to the rescue). I just have no idea why Mach3 should behave this way. Maybe it is a known quirk of the software. I copied the post nto the Artsoft forum to see if anybody closer to its' home might have experience of this. Anyway it is a problem solved, I just have to put the lids back on everything and start some cutting.
    Cheers,
    Rob
  1. Limits, homes, override switch
    By eurikain in forum General Electronics
    Last Post: 19-10-2016, 03:34 PM
  2. help with problem please
    By martin54 in forum General Electronics
    Last Post: 27-08-2014, 09:43 AM
  3. stepper acceleration rate - limits?
    By dsc in forum Stepper & Servo Motors
    Last Post: 02-03-2014, 02:25 PM
  4. limits on mill table
    By John11668 in forum Gantry/Router Machines & Building
    Last Post: 31-08-2011, 06:46 PM
  5. Limits or homing switchs???
    By Ross77 in forum Computer Software
    Last Post: 28-03-2010, 03:17 AM
