hi. I am using fusion 360 to write the g code and then downloading it to mach 3. but when I start the milling program the tool just starts to drill into the work piece. the first line of the program is
G90 G94 G91.1 G40 G49 G17
I am sorry I don't have any means to cut and paste the rest of the program. can anyone help me out. at a lost what to do.
21-03-2016 #2
The first line has nothing to do with why it's drilling into the work piece.
Also, someone needs to fix that post, as G90 and G91.1 should not be on the same line.Gerry
UCCNC 2022 Screenset
Mach3 2010 Screenset
21-03-2016 #3
The MAch3 post as it stands in Fusion has some issues that I do not like either. For example it uses g91 and g91.1 that make your code be incremental and not absolute. I only noticed that it was using these as Ger's screen has a nice bar at the bottom telling what is active.
The Linxcnc post is significantly simpler and I would recommend you give that one try.https://emvioeng.com
21-03-2016 #4
Terry just up load the txt file because without it there's nothing we can do to help.
Like the Lads say Fusion 360 Post processor is screwed up by the looks but without seeing the G-code it's impossible to tell what it's doing.
21-03-2016 #5
According to the line above, it uses G90 and G91.1.
The problem with them being on the the same line, is that if you are in G91 mode when you load the program, it won't switch to G90.Gerry
21-03-2016 #6
hi, this is the full g code to face the part.
(WHEEL SLOTS CUT FRONT FACE WHEEL FIRST CUT 3MM)
(T1 D=3. CR=0. - ZMIN=0. - FACE MILL)
G21
G28 G91 Z0.
G90
(FACE2)
M5
M9
T1 M6
S5000 M3
G54
M9
G0 X38.7 Y1.357
G43 Z15. H1
Z5.
G1 Z0.3 F333.
G18 G3 X38.4 Z0. R0.3
G1 X36.75
X0. F1000.
G17 G2 Y4.185 R1.414
G1 X36.75
G3 Y7.013 R1.414
G1 X0.
G2 Y9.842 R1.414
G1 X36.75
G3 Y12.67 R1.414
G1 X0.
G2 Y15.498 R1.414
G1 X36.75
G3 Y18.327 R1.414
G1 X0.
G2 Y21.155 R1.414
G1 X36.75
G3 Y23.983 R1.414
G1 X0.
G2 Y26.812 R1.414
G1 X36.75
G3 Y29.64 R1.414
G1 X0.
G2 Y32.468 R1.414
G1 X36.75
G3 Y35.297 R1.414
G1 X0.
G18 G3 X-0.3 Z0.3 R0.3 F300.
G0 Z15.
G17
M9
G28 G91 Z0.
G28 X0. Y0.
M30
22-03-2016 #7
22-03-2016 #8https://emvioeng.com
22-03-2016 #9
Hi.so the fault is something between the way the g code is written by fusion360 and the way mach 3 reads it. Ok but what is the fix?..
22-03-2016 #10
In the post processor option, use the linuxcnc option. Cannot remember off the top of my head how it is described.
Are you confident that you have the CAM model set up correctly? I can take a look for you if it helps. PM me your email and I will give you directions on how to do this.https://emvioeng.com
Fusion 360 - best approach?
By routercnc in forum Fusion 360Replies: 10Last Post: 18-06-2016, 07:49 AM -
First go at Fusion 360 Adaptive Clearing
By Washout in forum Fusion 360Replies: 0Last Post: 15-10-2015, 07:52 PM -
Fusion 360 - full, free 3D CAD and CAM.
By Leadhead in forum Fusion 360Replies: 5Last Post: 24-06-2015, 11:31 PM -
Cambium Code Web Tools – Parametric G-code Generation
By CambiumMachines in forum Manufacturer NewsReplies: 0Last Post: 09-01-2013, 04:56 AM -
Super X1 conversion - CNC Fusion kit
By bruce_miranda in forum Sieg Milling MachinesReplies: 12Last Post: 19-09-2008, 01:43 PM
