    My z drive will work when connected will x axis cable but won't work using its output.the Sri will move on screen the motor is making noise.below is a picture on the diagnostic screen there is a fault but I don't know how to repair it.
    Sent from my SM-G361F using Tapatalk
    When did it last work properly?
    What has changed since then?
    You've done half the diagnosis work, proving that tour Z motor works on an alternate driver, now you need to try your Z driver on another motor to definitively isolate the problem to just your Z driver.
    You don't give any details of your hardware, if I had this fault on my system I would swap out a driver but this is not an option on "All in One" Break Out Board and driver units where one failed driver renders the whole board scrap.
    I Changed the leads from the z to x then the x worked the z fine but the z driver would not work the x .I got the machine with this problem
    Examine all the components and tracks on the faulty driver section of the board (both sides) and compare to the good ones, I'm betting there's a toasted component or track somewhere on there.
  1. Z drive not working on cnc plasma
    By whensparksfly in forum Machine Discussion
    Last Post: 10-05-2016, 01:16 PM
  2. FOR SALE: Assembled Working Portabee
    By calida in forum Items For Sale
    Last Post: 19-09-2015, 10:17 AM
  3. x&z not working
    By cncjohn in forum Linear & Rotary Motion
    Last Post: 18-08-2013, 11:58 AM
  4. EXPERIENCE: Working with JAZZCNC
    By m.marino in forum Trading Experience & Feedback
    Last Post: 02-10-2012, 10:47 AM
  5. BobCAD CAM V24 Working with DXF files
    By aldepoalo in forum BobCAD-CAM
    Last Post: 19-03-2012, 07:17 PM
