    i need help on calculating the pulse equivalent for rack and pinion system and ball screw system....thnx
    Quote Originally Posted by yasser View Post
    We are not mind readers you need to give us more information.?
    hiii i built a cnc router ,i used rack and pinion for the x and y with gear ratio 1:5 and ball screw for the z with gear ratio 1:3 i am ysing a dsp hand controllrer the problem is the distance moved by the machine is not exact like the drawing it is as if it is scaled larger by 10%...there is a setting in the dsp hand that requires a parameter which is the no of pulse needed to move the machiene 1 mm pulse/mm so i guess there is a formula for rack system and another for ballscrew to calculate this parameter..thnx
    break this down into steps first. Working on Metric system.
    #1 Need Shaft Revs per Unit. So need tooth pitch(TP) and number of teeth on Pinion(PT). Shaft Revs per unti = 1 / (TP * PT)
    So example working on Mod 1 with 24 Teeth: Shaft revs per unit = 1 / (1 * 24) =0.0416
    #2 Motor Revs per unit With Ratio. For this we need number of teeth on Motor (MT) This is Motor Revs per unit = Shaft Revs per unit * PT / MT
    Example 0.0416 * 24 / 12 =0.0832
    #3 Steps Per Unit= Motor Revs * Microsteps. Example 0.0832 * 2000= 166.40 Steps per
  6. #5
    Use this calculator:
    http://mycnc.co.uk/coding/AxisCalculator.zip
  1. How-To: Feed Rate Calculation
    By Lee Roberts in forum Machine Discussion
    Last Post: 08-09-2016, 06:55 AM
  2. Stepper motor Pulse Signal Generator module
    By Tom J in forum Motor Drivers & Controllers
    Last Post: 12-01-2016, 10:47 AM
  3. My turn for help with Pulse multiplier for test rig.
    By JAZZCNC in forum Electronic Project Building
    Last Post: 20-06-2014, 05:09 PM
  4. MPG or Hand Wheel Pulse Encoder where to buy in UK?
    By suesi34e in forum Marketplace Discussion
    Last Post: 02-01-2014, 03:41 PM
  5. Pulse rate or dip switch settings
    By Jopo in forum Stepper & Servo Motors
    Last Post: 29-04-2013, 07:08 AM
