Thread: Denford Microrouter V4
just received the above machine today, does anyone know much about them?
it has a porters cable 23k spindle where is the best place to buy additional collets?
also is that a vacuum pump under the machine? what sort of vacuum table would I need to do work stuff on?
06-05-2016 #2
well that's me £450 lighter...
Ethernet smoothstepper
http://www.amadeal.co.uk/acatalog/Sm...ernet-794.html
3x drivers
https://www.cnc4you.co.uk/Stepper-Mo...tepping-CW5045
Breakout board
http://diycnc.co.uk/cnc-boards-uniport-v3/
48v psu
https://www.cnc4you.co.uk/Breakout-B...U-48Volt-12Amp
The Following User Says Thank You to andy_con For This Useful Post:
Well done, bring on the retrofit !
.Me.Me
19-05-2016 #4
ok im struggling its not going as well as id like
ive got a tiny amount of movement on the Y but cant get others moving
ive done in
but unsure if I need to do this
25-05-2016 #5
anyone got any thoughts on how to connect up this BoB -
https://www.cnc4you.co.uk/Breakout-B...xis-with-Relay
to a spindle v4 board
http://www.diycnc.co.uk/forms/spindleV4.pdf
01-06-2016 #6
lots of help, offered.
thanks
01-06-2016 #7
At first look it appears incompatible to me as your bob is lacking outputs pin 14 on port is usually linefeed or control 1 as used on board shown in spindle board diagram this is not available on your BOB I would contact DIYCNC on the email on instructions tho they may just say buy another bob or possible take feed directly from parallel port.
Knowing nothing about these particular boards I could not advise on non standard wiring.
Just noticed your using a smoothstepper so may be able to pick up 14 16 17 and Gnd from that again not familiar but from memory what I have read may be possible.
A quick google sugests this is possible but be aware that they use the old wiring on the board according to what I read 1-13 on one side and 14-26 on other standard now is odd one side even the other.Last edited by lucan07; 01-06-2016 at 09:28 PM.
Looking good Andy!
.Me.Me
The Following User Says Thank You to Lee Roberts For This Useful Post:
FOR SALE: Denford Starmill ATC
By andy_con in forum Items For SaleReplies: 1Last Post: 14-02-2016, 10:16 PM -
1999 Denford Microrouter problems
By D-man in forum Denford RoutersReplies: 5Last Post: 21-03-2015, 12:43 PM -
Denford MicroRouter Compact, what to do next?
By paul_m in forum Denford RoutersReplies: 2Last Post: 08-01-2015, 09:51 AM -
FOR SALE: Denford cnc
By john legge in forum Items For SaleReplies: 4Last Post: 17-03-2013, 11:18 PM -
Denford CNC MicroRouter
By mekanik in forum Milling Machines, Builds & ConversionsReplies: 12Last Post: 27-08-2012, 06:57 PM
