Page 5 of 10 FirstFirst ... 34567 ... LastLast
  1. #41
    I'm nipping down to Swindon one day next week, anyone in the East Mids want any bringing back but you will have to collect from me.
    I'm not shipping out.
    Price is 12.99 for the PS, no other costs.
    John S -
  2. #42
    Tom's Avatar
    Location unknown. Last Activity: 30-11-2016 Has been a member for 7-8 years. Has a total post count of 172. Referred 1 members to the community.
    Aargh,
    Cheers for the offer John, I would've done but paid for mine earlier. In fairness he only charged 12 shipping for 2 units so it's all good.
  3. #43
    John
    Pop on in if for a mug of tay and knobs if you do, and i might even get some of those things you like so much in as well.
  4. #44
    Will do and send a PM when I get a reply on times and dates.
    John S -
  5. #45
    ecat's Avatar
    Location unknown. Last Activity: 08-02-2014 Has been a member for 6-7 years. Has a total post count of 157. Received thanks 5 times, giving thanks to others 8 times.
    Well, they have arrived. Impressive beasts, especially the big hole in the middle to facilitate passive cooling.
    irving2008, could you possibly link me to the UCC2985 application note or spec sheet, google is not helping :(
  6. No, I cant find it again either... but if memory serves (and I'll have to look when I get home) I didnt find it before but a near match - enough to give pinout and reference circuit clues... but I dont recall offhand what it was or where I found it...
    *edit* might have been a typo.... UCC2895 datasheet
  7. #47
    ecat's Avatar
    thank you anyway.
    An older part perhaps? There is certainly enough info on the, what I suspect to me similar, ucc2884, 3884.
    If I can track down a comparator feeding the opto-isolators then the switching chip may be irrelevant. You mention a second opto, could this be for over-voltage?
    Output -> voltage divider -> comparator -> opto... if nothing else the feedback circuit could be replaced.... heh... maybe :)
    Guessing again, the comparator - in custom chip or not - is running from +5v or +12v, so there must (-ish) be a voltage divider external to the custom chip/comparator etc.
    Anyway, we know these are good for 42v.
    Drivers that can cope with the full 56v are not so expensive (?)
    On a personal note, if the worst comes to the worst, I now have the makings of +/-56v psu @ 500w which will make for a stonking sub-base amp :)
  8. #48
    ecat's Avatar
    Some initial investigation:
    PWM controller : http://www.digchip.com/datasheets/pa...C2895N-pdf.php
    The interesting parts on the surface mount board are, guessing here as I've not buzzed things out or even applied power yet!!! :
    Op-Amps : lm224 equivalents
    Comparators: lm239 equivalents
    Now I guess the fun can begin :)
  9. well I got as far as setting up my test bed again yesterday to restart the investigation but got sidetracked (watching TV while probing 400V isnt a good idea)... This link gets you to datasheet and applications notes.
  10. #50
    ecat's Avatar
    probing 400v at any time is not a good idea imo!
    Anyway, that daughter board is a nightmare, everything is way to small and the board would be trouble to remove: I think I have the comparator outputs to the 2 optos, via 2 transistors so looks good :) The bad news is all the fun gubbins for this is behind the capacitor bank making it almost totally inaccessible :(
    Undeterred, lol, I moved on to the inputs to the daughter board and here I may have hit the jackpot... maybe.. The op voltage is divided down by a factor of ten and fed to the daughter board. Yay. These dividers are on the main board and not surface mount. Yay. The bad news is there are two voltage dividers and I have no idea what the second one is for, then again I have no idea which of the 2 we need anyway.
    Divider 1 feeds op div 10 (measured) to daughter board pin 12
    Divider 2 feeds op div 10 (measured) to daughter board pin 8
    You should be able to trace the resistors I'm talking about from these pin numbers.
    If I'm right about the lm224 equivalents then pin 12 feeds to a unity gain op amp, pin 8 feeds to a different opamp that actually 'does stuff'. I've no idea what it does but it's not unity gain.
    So, why two dividers and two opamps ? 1 to catch the default 42.9v and the other for the variable feature? I don't know. Do I need to change both? I don't know.
    These boards were not made for easy disassembly so I've measured the divider resistors in circuit, of course the values measured this way do not match the values required for a div 10 series pair. Ho-hum. One resistor in each pair is big and easy to see - they are not quite under the heatsink and just behind the output coils, I can't see a ref number now the thing is back together :( -, so if you have reasonable colour vision perhaps you can let me know the value?
    Anyway, before I risk life and limb by snatching the soldering iron from the coals (should be hot enough by now) I'd like your opinion on which of the two possible modifications would be most suitable...
    1) Configure the psu so the variable range works over, say 43v to 47v (ish)
    2) Configure the psu so the 'non-regulated' voltage can be set to XXv and the variable input can be ignored.
    I'm off to try and find a zener...
  1. can I have my power supply in a seperate box?
    By nobby in forum General Electronics
    Last Post: 12-06-2013, 10:33 PM
  2. Replies: 0
    Last Post: 25-01-2012, 08:29 PM
  3. FOR SALE: 50V 20A Power supply
    Last Post: 30-05-2011, 10:01 PM
  4. 12V Fan off 230v power supply ?
    By Buba b in forum General Electronics
    Last Post: 02-03-2010, 08:51 PM
  5. power supply
    By hitmythumb in forum General Electronics
    Last Post: 21-06-2009, 09:27 AM
