Thread: ATC Options?
Page 1 of 3 123 LastLast
  1. Just supposing it were possible ;)
    If I wanted to fit an auto-tool-changer to my mini mill, what would be used for the spindle?
    That seems to be the only stumbling block really, the rest is just building and macro stuff. There seem to be a few variations - carousel, straight bank etc but all need a spindle that can be released automatically.
    Are ATC's for the rich boys only??
    OR for those that can justify 1500 for automation because it will pay for itself! Few on Aliexpress starting around $2000
  3. Bum, would have gone 5-600 just for the luxury but that's just too much ;)
    Haven't seen any cheap DIY worth looking into I think this is about closest but not for me.
    https://www.youtube.com/watch?v=jHofj3efzfo
    Lives in East Lothian, United Kingdom. Last Activity: 8 Hours Ago Has been a member for 9-10 years. Has a total post count of 2,060. Received thanks 228 times, giving thanks to others 5 times.
    The spindle is the hard part.
    Quite a few people use the Tormach system (TTS), which I think is essentially a modified R8 spindle/collet setup.
    You could go for a conventional ISO/BT spindle with a drawbar, and attach an airgun for loosening/tightening the drawbar.
    Best option is some form of ISO/BT gripper spindle, but they are expensive. I'm sure I've seen ISO30 ATC spindles for around 800, however you need to add a motor to that.
    I still have a DaleCNC ISO15 spindle cartridge sat in the workshop doing nothing if you're interested. It cost me about $1200, but I'm open to sensible offers as I've currently got no plans to use it on anything.
  6. its not too bad at the low speed end but my spindle is a 24,000rpm water cooled job, my machine was built for aluminium really so it needs the speed. Looking at 1600-2300 on Aliexpress :(
    I saw this skyfire cnc cartridge a while back. I don't know if it was ever launched - there was quite a thread on cnczone but it wasn't clear if they ever shipped anything. Pretty cheap, although needs a motor and an air cylinder on the drawbar, and is 6000rpm max.
    http://www.skyfirecnc.com/picshow.asp?id=24
  8. Yep, plenty similar on Aliexpress, BT30, ISO25 sockets but all are low rpm so not really what i was after :)
    There is a German company that does them for Kress and watercooled spindles http://www.sorotec.de/shop/Spindles/...ME-800-V2.html
    https://emvioeng.com
    Then you are going to struggle as once you go bigger on diameter to take a QC taper the bearings needed won't hold up to 24K
    If you can get away with just two tools, roughing and finishing then think about another 24K spindle mounted on another set of rails on the Z axis that can pneumatically push the second cutter down lower than the roughing cutter. Software then calls up the respective offsets and runs the second spindle.
    You can get a completer second spindle and inverter for as low at 175 on Ebay.
    John S -
  1. Linear bearing upgrade options?
    By Joe in forum Rails, Guideways & Bearings
    Last Post: 04-03-2015, 08:22 PM
  2. Profile Cutting Options BobCAD CAM
    By aldepoalo in forum BobCAD-CAM
    Last Post: 25-06-2013, 08:10 PM
  3. options for 3020 router spindle?
    By arborealad in forum Milling Machines, Builds & Conversions
    Last Post: 19-11-2012, 09:13 PM
  4. water cooling options for spindle
    By routercnc in forum Tool & Tooling Technology
    Last Post: 12-02-2012, 10:22 PM
  5. Machine rebuild time - options...
    By CraftyGeek in forum Gantry/Router Machines & Building
    Last Post: 19-10-2011, 09:26 PM
