Thread: ATC Options?
Page 3 of 3 FirstFirst 123
  1. #21
    Quote Originally Posted by andy_con View Post
    do you need such a high spindle speed?just think a large machine like a haas has an 8-10k spindle speed with bucket loads of torque and that can cut fast and deep. its not all about spindle speed but machine strength and torque. so could you get away with a slower but more powerful spindle?
    Unless your using small tools then speed is required.!! . . . This is small light duty machine who's main operation will be with small tooling requiring high speeds 10K minimum.
  2. #22
    Interesting,
    Just calculated the speeds for a 2mm cutter in 6061T6 and it seems I am seriously under-using carbide anyway.
    In Carbide, at full speed it needs 82,000rpm, HSS wants 23,000rpm
    The reason I had not seen the high speed before was because I limited HSMAdvisor to calculate feeds based on my limit of 24,000rpm, removing this limit shows the full feed & speeds.
    Anyone got an 82,000rpm spindle? :)
    Anyway, HSS will do the job at say 6000rpm but it will be much slower.
  3. #23
    Should that be "Unless your'e using large tools" there Jazz?? :)
  4. #24
    My denford triac has a 4k spindle and I don't have any problems.
    I do 2mm deep cuts using an 8mm cutter at f250
  5. #25
    Nope said correctly Andy said Speed wasn't required. I Said "Unless using small tools" Then speed is required.
    Compared to me doing 4mm Doc at F900. 11000rpm!! . . . . BIG DIFFERENCE. . . Oh and that's on Router not a Mill.!
  6. #26
    I stand corrected ;)
    Yes, speed is needed, it can be done on a slow machine - i've used 1/16" on the old bridgeport before but the feed rate is microscopic!
    The high speed spindle is very useful.
  1. Linear bearing upgrade options?
    By Joe in forum Rails, Guideways & Bearings
    Last Post: 04-03-2015, 08:22 PM
  2. Profile Cutting Options BobCAD CAM
    By aldepoalo in forum BobCAD-CAM
    Last Post: 25-06-2013, 08:10 PM
  3. options for 3020 router spindle?
    By arborealad in forum Milling Machines, Builds & Conversions
    Last Post: 19-11-2012, 09:13 PM
  4. water cooling options for spindle
    By routercnc in forum Tool & Tooling Technology
    Last Post: 12-02-2012, 10:22 PM
  5. Machine rebuild time - options...
    By CraftyGeek in forum Gantry/Router Machines & Building
    Last Post: 19-10-2011, 09:26 PM
