Thread: Aluminium adhesive
12-09-2013 #1
Just about to assemble the gantry (50x100x6 aluminium box section). I was originally going to bolt it together, but now may have it welded. But unsure of welding due to possible distortion so was wondering if anyone has used any form of adhesive to join aluminium?
If so what adhesive and how well did it work. Does it reduce flex over bolting the box section together. Will welding them distort?Dan
12-09-2013 #2
Same question myself, there seems to be plenty of choice re. adhesive but as you say first hand experience feedback is required.
12-09-2013 #3
Don't know about adhesives, but I think welding will cause even greater distortion than with steel. G.
12-09-2013 #4
You could always try Durafix brazing sticks, I've just bought one to try!
12-09-2013 #5
When I built my router (primarily to make PCBs) out of aluminum, and not having access or the ability to TIG, I chose to bolt and use Loctite E-20NS adhesive.
That has been a couple of years now and the machine is still "glued" together!
Along the line, I have also done some milling and engraving of aluminum and brass! YMMV, but I am sold on it1Last edited by C_Bubba; 12-09-2013 at 10:59 PM.
Art
AKA Country Bubba
(Older than Dirt)
12-09-2013 #6
Wouldn't weld it together aluminium distorts something silly when welded and then it will be stressed so will start changing shape when these stress's release over time.!!. . . . Just bolt it together with adhesive like Loctite or epoxy.
12-09-2013 #7
Have a look at Structural epoxy.
3m make a good range.
They bond Ali, Steel and other stuff.
check out this lo-tech, but impressive demo.
DP-420 3M EPOXY overlap shear test by Doctorbass PART 1 - YouTube
it aint cheap tho, surprisingly
Edit: There are now room temperature versions that are very nearly as strong.Last edited by Greeny; 12-09-2013 at 11:16 PM. Reason: added stuf
13-09-2013 #8
That's the key word 'structural'
13-09-2013 #9
As I understand it, surface prep is the key (pun unintended) to glueing aluminium - do exactly what the instructions that come with the glue say and if you can't (temperature constraints etc), find a different glue.
I would use enough bolts to put it on the skimpy side of ok without the glue and use the glue to provide a safety margin and extra rigidity. Doing it this way you might not need such fancy (expensive) glue.
I was thinking of using a medium strength loctite for the rail and linear bearing contact surfaces - one that would be separable if necessary but would stop any slippage.
13-09-2013 #10
Thanks for the input guys. I will go with the bolt & adhesive option then. Will go for a loctite structural epoxy, grade tbc.
I'm guessing the entire surface won't have to be coated only dabs equally spaced across the area?
With the fixings to bolt the ballscrew bearings on etc do people tend to loctite these in due to vibration or use spring washers or nothing at allDan
Aluminium box section
By martin54 in forum Gantry/Router Machines & BuildingReplies: 11Last Post: 28-10-2012, 01:13 AM -
BUILD LOG: Aluminium CNC log.
By jcb121 in forum DIY Router Build LogsReplies: 111Last Post: 04-04-2012, 01:37 AM -
First Aluminium cut
By luke11cnc in forum Computer SoftwareReplies: 15Last Post: 24-02-2012, 09:39 AM -
Aluminium passivation - for aluminium to be used outside
By CHudson in forum Metal Finishing TechniquesReplies: 4Last Post: 06-04-2011, 09:18 PM -
MDF or Aluminium
By rob_colby in forum Gantry/Router Machines & BuildingReplies: 3Last Post: 24-10-2010, 09:36 PM
