    My Z drive not working on cnc plasma it will read movement when movinment on the mach3 dro when using the keyboard or in running a program but won't drive the motor. I have tested the motor seem to work fine any ideas
    Sent from my SM-G361F using Tapatalk
    Lives in Marple Stockport, United Kingdom. Last Activity: 48 Minutes Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 3,333. Received thanks 618 times, giving thanks to others 78 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Quote Originally Posted by whensparksfly View Post
    You seem to have two separate posts running, Is this all the same problem? You need to say what the setup is ie what stepper and drive what BOB and how is it being driven.
    Has it ever been working?
    I have the x and y working its just the z works on the dro and dosnt run the motor unsure of what exactly is used internally as I bought the machine
    Any ideas
    Any ideas
    How can anybody have any ideas if you don't post more info.
    Post some pictures of what you have and screen shots of ports and pins in Mach3 etc
    Below is the diagnostic screen and main it will move the s axis on the dro the motor is making noise and will work if conected to the x axis wire
    I've checked all the wiring seem to be correct is there somthing in the mach software that could be causing this
    Only thing in software likely to cause problem is Configuration which you can set, if you want to check and find problem swap over X and Z axis motors and move carefully if X stops working and Z works its either the wiring or configuration in Mach3 as motor etc fine then you could swap back and just swap driver over to check Driver ok, I would first of all post your Input settings For XY&Z and current Motor tuning for X and Z axis as it may well be obvious from those what your problem is.
    Swaping the driver's or swapind the motor wires from z to x makes no difference I will post a picture on input tomorrow thank you for you help
    So your saying if you swap Z axis motor wires to the Working X axis drive it still doesn't work.? If so then dead motor.
    (Daft question here.? . . . Obviously swapping Z motor to X axis will only work if you jog X axis your not swapping then trying to jog Z are you.?)
    Have you tried swaping Z axis drive to the X axis motor.? This will eliminate dead Z axis drive. IF Z drive works X motor then sounds like your Z axis motor is dead.
  1. Metal Working Lathe
    By DanBlack in forum Lathes, Lathe Rebuilding & Conversions
    Last Post: 18-06-2015, 09:47 AM
  2. x&z not working
    By cncjohn in forum Linear & Rotary Motion
    Last Post: 18-08-2013, 12:58 PM
  3. EXPERIENCE: Working with JAZZCNC
    By m.marino in forum Trading Experience & Feedback
    Last Post: 02-10-2012, 11:47 AM
  4. WANTED: OLD LATHE wanted..WORKING OR NOT
    By dannymac in forum Items Wanted
    Last Post: 25-01-2012, 10:06 PM
  5. Plasma Cutter Drive
    By antsals in forum Plasma Table Machines
    Last Post: 23-08-2010, 05:28 PM
