Page 19 of 31 FirstFirst ... 9171819202129 ... LastLast
  1. #181
    Bravo!
    .Me
    .Me
  2. Fitted some chip covers for the ways, nitrile rubber, tomorrow will be making the belt covers for X&Y drives.
    Lowest and most forward position...
    The front cover will just hang over the front like many of the real CNC Bridgeports do.
  3. Got the X&Y axis chip covers fitted today...
ID:	19064Click image for larger version.
    Also found this on the welding bench....
    Should help a bit :)
  4. #184
    Its good to have a plasma machine at workshop
  5. The Following User Says Thank You to Boyan Silyavski For This Useful Post:
  6. Made some button tags today, i've also had the console powder-coated :)
    Coming along nicely
  7. #186
    Very nice Dave and pro.
  8. Looking great. Did you buy the blank tag material already made up or did you have to stick layers together? Can you let me know what the material is and where you got it? Thanks
  9. I got it from here https://hindleys.com/index.php/ Its 1.5mm black-white-black engraving plastic, 600x300 sheet, 14 delivered.
    First time i've used it and came out perfect, used a 30deg engraving tool, 0.2mm tip, 24000rpm, 900mm/min, air blast only and used an Aspire V-Carve path. Outer edges were cut with a 2mm single flute carbide bit with 6mm x 0.6mm tabs.
  10. Quote Originally Posted by Davek0974 View Post
    Thanks Dave one project to add to my list !
  11. #190
    Neale's Avatar
    Lives in Plymouth, United Kingdom. Last Activity: 9 Hours Ago Has been a member for 4-5 years. Has a total post count of 1,065. Received thanks 190 times, giving thanks to others 5 times.
    I'm going to need some of that plastic soon - good to see a source of smaller pieces at not-too-unreasonable prices. An 8x4 sheet would last me quite a long time...
  2. Manual autochanger problems.
    By Saracen in forum Lathes, Lathe Rebuilding & Conversions
    Last Post: 05-02-2015, 01:14 AM
  3. WANTED: Centec 2A manual
    By Web Goblin in forum Items Wanted
    Last Post: 03-09-2012, 09:56 AM
  4. Translating the manual
    By Robin Hewitt in forum Moulding Machines
    Last Post: 01-09-2012, 01:21 PM
  5. Bridgeport Conversion
