    You lose Z travel when you convert the bridgeport's quill and another bit more when you add the adapter to hold the high speed spindle. Apart from that, I cannot see any issues except the speed at which your motors are able to move the bed. Good lubrication is key here. 4-5000 is way to quick for stepper conversions but possible with good servos. I have restriced mine to 3000mm/min actually.
    https://emvioeng.com
    Ok, but by building a custom Z-axis and mounting it on the rear of the ram I would retain whatever travel I build into the new axis, it means swivelling the ram round to change from heavy to light milling but thats about it, plus would need two z-axis drives - heavy and light.
    The Z on the heavy side is a pain, a couple that i have seen today - one replaced the quill lever with a toothed pulley and drove that via a planetary gearbox reduction - seemed ok, another replaced the fine-feed hand wheel and drove that, the ones that mount to the front of the quill I am not too impressed with, have read a few tales of quills being trashed by the single bolt pulling out.
    As for speed, so far most of my mini-mill work ranges from 600mm/min to 150mm/min - hardly blistering, I'm sure the old girl can match that ;)
    I think this may be an interesting project.
    Yes, that would do it. I have gone with direct drive on the quill and do not over drive it. The fine feed goes through a clutch while the backlash on the lever is too much for CNC.
    Good points, thanks.
    By direct, I gather you have the screw nut coupled to the front where the depth-stop used to sit?
    It's slippery slope and quickly your into it $$$ before too far to stop.!! . . . Don't Do it Listen to John S.
    awww, bum, damn that cold hard logic JAZZ ;)
    In my defence, it would pretty much fit in with exactly what i want though!
    So, the alternatives then -
    Find a donor machine and hopefully just fit the electrics?
    Downsides I can see...
    space - nowhere to put it.
    would like a big table again - this seems to mean a big machine (see point above)
    transport costs
    unknown wear & tear
    different tooling probably
    This seems not too bad, but its bed is quite small, although it does have an ATC - would that be the sort of stuff to search for???
    http://www.ebay.co.uk/itm/1821213470...%3AMEBIDX%3AIT
    Yep I'd take that every time over converting BP.
    Something that rarely gets mentioned...Power required...
    I have a 3ph 2.2kW spindle motor on a vfd, 700w X servo, 700w Y servo, 400w Z servo, maybe 100w for pc and controller on this machine.
    How do i calculate the supply capacity allowing for diversity - it will not be running 100% flat out all the time :)
    I know i need to uprate the MCB's and supply cables as the build was originally for the small 1.5hp spindle motor.
    Adding up the maximum ratings for all drives gives a figure way more than i can supply :)
    A quick mental calc, and I'd say 16A would cover you.
    2200+700+700+400 = 4000.
    Divide that by 220 gives 18A, or 250 gives 16A.
    Power up surges of the drives are likely to give a bigger problem than too much current draw during use.
    Thanks, so there is no difference in current draw if a 3ph motor is running on 3ph or on converted single to 3ph via a vfd (apart from the internal vfd usage) ??
  2. Manual autochanger problems.
    Last Post: 05-02-2015, 01:14 AM
  3. WANTED: Centec 2A manual
    By Web Goblin in forum Items Wanted
    Last Post: 03-09-2012, 09:56 AM
  4. Translating the manual
    By Robin Hewitt in forum Moulding Machines
    Last Post: 01-09-2012, 01:21 PM
  5. Bridgeport Conversion
