Page 1 of 3 123 LastLast
    iD2's Avatar
    Lives in Bangkok, Thailand. Last Activity: 27-07-2016 Has been a member for 5-6 years. Has a total post count of 15.
    Hello, This my first time post at this forum. Let's go to see my design first and this was the 3rd machine i design , the other 2 model you can see it at my blog --> iD2CNC.com
    For dual Y axis --> iD2CNC v.2.0 (Dual Y Axis)
    For single Y axis --> iD2CNC v.1.0
    Start with my design ::
    iD2CNC-SS Machine v.1.0 Specification (65cm x 45cm x 15cm , XYZ) ::
    – Machine working area 650mm x 450mm.
    – Machine size 1,050mm x 800mm x 750mm (width (X) x length (Y) x height (Z)).
    – Linear rod rail size 16mm (RM1605/RM1610) for all axis.
    – Ball screw 16mm (RM1605/1610) for all axis.
    – Use standard ball screw support BK/BF12 , FK/FF12.
    – Aluminum frame use aluminum alloy 5083 10mm & 12mm.
    – Design using metric unit (mm).
    iD2CNC-SS Machine v.1.0 Specification (65cm x 65cm x 15cm , XYZ) ::
    – Machine working area 650mm x 650mm.
    – Machine size 1,050mm x 1,000mm x 750mm (width (X) x length (Y) x height (Z)).
    iD2CNC-SS Machine v.1.0 Specification (65cm x 85cm x 15cm , XYZ) ::
    – Machine working area 850mm x 650mm.
    – Machine size 1,050mm x 1,200mm x 750mm (width (X) x length (Y) x height (Z)).
    iD2CNC-SP Machine v.1.0 Specification (65cm x 65cm x 15cm , XYZ) ::
    – Machine working area 650mm x 650mm x 150mm , XYZ.
    – Machine size 950mm x 1,050mm x 780mm (width (X) x length (Y) x height (Z)).
    – Linear rod rail size 16mm (RM1605) for Z axis.
    – Linear rod rail size 20mm (RM2005 / 2010) for X,Y axis.
    – Ball screw 16mm (RM1605) for Z axis.
    – Ball screw 20mm (RM2005/2010) for X,Y axis.
    – Use standard ball screw support BK/BF12 , FK/FF15.
    – Aluminum frame use aluminum alloy 5083 10mm & 12mm & 15mm.
    iD2CNC-SP Machine v.1.0 Specification (65cm x 85cm x 15cm , XYZ) ::
    – Machine working area 650mm x 850mm x 150mm , XYZ.
    – Machine size 950mm x 1,250mm x 780mm (width (X) x length (Y) x height (Z)).
    iD2CNC-SP Machine v.1.0 Specification (85cm x 125cm x 15cm , XYZ) ::
    – Machine working area 850mm x 1250mm x 150mm , XYZ.
    – Machine size 1,150mm x 1,650mm x 780mm (width (X) x length (Y) x height (Z)).
    iD2's Avatar
    Start assembly Y axis (Base)
    All aluminum was cut by cnc water jet.
    iD2's Avatar
    iD2's Avatar
    iD2's Avatar
    Frame & X axis assembly ::
    Nice looking machine! What are you planning to cut with it? /Madman
    iD2's Avatar
    Thank you , this machine use for cut wood , acrylic , pvc , aluminum sheet.
    iD2's Avatar
    Jpeg
    Jpeg
    Jpeg
    It looks good! I have not built my own router yet, still planning ;) So you have alot more experience thanks me, but have you tried to cut aluminium with this design? From what Ive read the tall thin gantry uprights are more suitable for wood and plastic? Best of luck to you!
    iD2's Avatar
    Z Axis assembly ::
    Jpeg
    Jpeg
    Jpeg
    Jpeg
    Jpeg
    Jpeg
    Jpeg
    Jpeg
    Jpeg
  1. Aluminum finish
    By Boyan Silyavski in forum Metal Finishing Techniques
    Last Post: 07-09-2014, 07:32 PM
  2. Aluminum router build - Could use some input
    By Tumblebeer in forum Gantry/Router Machines & Building
    Last Post: 01-09-2014, 09:48 PM
  3. NEW MEMBER: where to buy aluminum extrusion
    By troyboy1 in forum New Member Introductions
    Last Post: 21-07-2014, 01:52 PM
  4. tool for aluminum on uk
    By edgas10 in forum Tool & Tooling Technology
    Last Post: 26-04-2011, 11:23 AM
