    This is the mill screen the drawing is to scale here
    This is my plasma screen
    Sent from my SM-G361F using Tapatalk
    What version of software are you running looks nothing like my screens for plasma cutter, looks like you may need to update to Version R3.043.066 just corrected your code and loaded into that with no problems.
    What size did the flange come out at ?
    How do I update it
    190mm and you go to the Artsoft site and download latest version and install it thats why you buy a licence for updates and support.
  5. #15
    Lives in Plymouth, United Kingdom. Last Activity: 27 Minutes Ago Has been a member for 9-10 years. Has a total post count of 1,729. Received thanks 295 times, giving thanks to others 11 times.
    Worth checking that "steps per" settings are correct in Mach3? Or do gcode files from other CAM packages work ok?
  6. #16
    It is a full version I just do have the details.It seem like a old version
  7. #17
    You can download latest version for free, when you install if licence is valid its unlimited and if not it limits to 500 lines I believe.
  8. #18
    I'll try tomorow
  9. #19
    Ok tried in New program exactly the same.I then the set the steps per unit put in 40 witch should be 40mm and the axis took off thinks is in inchs .
    I check native units and unit in setting are in mm. Atached is my motor tunning
  10. #20
    For motor tuning I set and save a value and then manually command a small move of a couple of mm, fiddle with the tuning until that's close then play with larger moves, working up to something close to full travel.
    That way you aren't making any assumptions or guesses,
    - Nick
  1. Replies: 14
    Last Post: 11-05-2016, 09:15 PM
  2. No detail imported stl file
    By luke11cnc in forum Rhino 3D
    Last Post: 30-01-2015, 10:19 PM
  3. RFQ: 5mm steel plate plasma or laser - can supply sheetcam g-code for mach 3,
    By nobby in forum Projects, Jobs & Requests
    Last Post: 07-03-2014, 07:56 PM
  4. Imported L298 Arduino Modules
    By boldford in forum Motor Drivers & Controllers
    Last Post: 30-07-2012, 11:06 PM
  5. Increasing timing pulley bore size from 3mm t0 3.175mm
    By divdav in forum Gantry/Router Machines & Building
    Last Post: 14-05-2011, 09:45 AM
