    I had another thread on a problem I've been having I nearly sure it now is the motor tunning.I have the native etc set for mm but It alway seems to go 40inchs rather than 40mm has anyone any details on how exactly to do it
    Sent from my SM-G361F using Tapatalk
    Motor tuning, whatever units it's set in, gets down to measuring travel and adjusting the units.
    Start with a 1mm move and adjust settings so it's near, then go to a 10mm move and adjust so it's near.
    After that try whatever distances you have good measuring equipment for, I use a DTI and guage blocks.
    Call your moves from the MDI tab,
    That's it,
    - Nick
    How do you set the unit be it inch or mm
    Found this on cnczone can't find it though
    Config - Select Native Units
    You will note from the pop up that this is for motor tuning and doesn't affect how G-Code is interpreted.
    Call a move, measure travel, adjust units, don't rely on automated motor tuning,
    - Nick
    Do you do it manually in the motor tunning drop down or do it in the setting move x 20 how far did x move
    Quote Originally Posted by whensparksfly View Post
    I've never used the drop down motor tuning do-dad, I've always started manually from the steps per turn for the steppers, screw pitch etc. then measured some moves, starting small then getting bigger, adjusting the tuning figures to correct over/under size moves
    Mach3 has an auto calibration feature on settings page just install a recent version!
    It's worth asking on the Mach3 forum which version is best for your application, latest is not best for all applications, new bugs were introduced as old ones were fixed.
    I did play with the auto feature it wanted me afterwards to select a higher Kernel Speed
  1. Random G-code for testing motor tuning.
    By Jonathan in forum Stepper & Servo Motors
    Last Post: 30-10-2019, 08:22 AM
  2. Motor tuning and switches
    By glynster in forum General Electronics
    Last Post: 15-03-2015, 12:27 AM
  3. Plasma tuning speed...
    Last Post: 12-02-2014, 10:45 AM
  4. Help please with motor tuning mach 3.
    By Kevin1970 in forum Artsoft Mach (3 & 4)
    Last Post: 13-06-2012, 10:22 PM
