Page 2 of 6 FirstFirst 1234 ... LastLast
    Quote Originally Posted by whensparksfly View Post
    It dose it in a few codes I've tried to you have any code I can try
    Sent from my SM-G361F using Tapatalk
    You should post some code here with which the problem occurs
    I tried to load a video the z just keeps moving down past 0 and keeps going on down levels out eventually
    A video
    A video
  5. #15
  6. #16
    [IMG]https://uploads.tapatalk-cdn.com/20160528/802f237ec5fe912cddb6f0b3721664
  7. #17
    Hk
  8. #18
    Woops tried to delet made it worse
  9. #19
    N0010 (Filename: nigel first flange final.tap)
    N0020 (Post processor: Mach3.scpost)
    N0030 (Date:24/05/2016 Time:01:13:16)
    N0040 G21 (Units: Metric)
    N0050 G40 G90 G91.1
    N0060 F1
    N0070 (Part: nigel first flange)
    N0080 (Operation: Outside Offset, 0, T1: Plasma, 0 mm kerf)
    N0090 (Plasma, 0 mm kerf)
    N0100 T1 M06
    N0110* G43 H1
    N0120 G00 Z20.0000
    N0130 X95.8839 Y95.8838
    N0140 Z10.0000
    N0150 G01 Z1.500 F100.0
    N0160 F440.0
    N0170 X94.1162 Y94.1161
    N0180 G00 Z20.0000
    N0190 Y95.8839
    N0200 Z10.0000
    N0210 G01 Z1.500 F100.0
    N0220 F440.0
    N0230 X95.8839 Y94.1162
    N0240 G00 Z20.0000
    N0250 X95.0000 Y20.0001
    N0260 Z10.0000
    N0270 G01 Z1.500 F100.0
    N0280 G03 X95.0000 Y20.0001 Z1.5000 I-0.0000 J74.9999 F440.0
    N0290 G00 Z20.0000
    N0300 X94.6339 Y4.9339
    N0310 Z10.0000
    N0320 G01 Z1.500 F100.0
    N0330 G03 X94.6339 Y4.9339 Z1.5000 I0.0000 J4.6999 F440.0
    N0340 G00 Z20.0000
    N0350 X155.9880 Y29.3121
    N0360 Z10.0000
    N0370 G01 Z1.500 F100.0
    N0380 G03 X155.9880 Y29.3121 Z1.5000 I0.0000 J4.6999 F440.0
    N0390 G00 Z20.0000
    N0400 X182.1339 Y89.9339
    N0410 Z10.0000
    N0420 G01 Z1.500 F100.0
    N0430 G03 X182.1339 Y89.9339 Z1.5000 I0.0000 J4.6999 F440.0
    N0440 G00 Z20.0000
    N0450 X157.7557 Y151.2880
    N0460 Z10.0000
    N0470 G01 Z1.500 F100.0
    N0480 G03 X157.7557 Y151.2880 Z1.5000 I0.0000 J4.7000 F440.0
    N0490 G00 Z20.0000
    N0500 X97.1339 Y177.4339
    N0510 Z10.0000
    N0520 G01 Z1.500 F100.0
    N0530 G03 X97.1339 Y177.4339 Z1.5000 I0.0000 J4.7000 F440.0
    N0540 G00 Z20.0000
    N0550 X35.7798 Y153.0558
    N0560 Z10.0000
    N0570 G01 Z1.500 F100.0
    N0580 G03 X35.7798 Y153.0558 Z1.5000 I0.0000 J4.7000 F440.0
    N0590 G00 Z20.0000
    N0600 X9.6339 Y92.4339
    N0610 Z10.0000
    N0620 G01 Z1.500 F100.0
    N0630 G03 X9.6339 Y92.4339 Z1.5000 I0.0000 J4.6999 F440.0
    N0640 G00 Z20.0000
    N0650 X34.0120 Y31.0799
    N0660 Z10.0000
    N0670 G01 Z1.500 F100.0
    N0680 G03 X34.0120 Y31.0799 Z1.5000 I0.0000 J4.6999 F440.0
    N0690 G00 Z20.0000
    N0700 X95.0000 Y-0.0000
    N0710 Z10.0000
    N0720 G01 Z1.500 F100.0
    N0730 G02 X95.0000 Y-0.0000 Z1.5000 I-0.0000 J95.0001 F440.0
    N0740 G00 Z20.0000
    N0750 M05 M30
  10. #20
    A mental speeds is too high warring just came up
  1. Replies: 9
    Last Post: 23-05-2015, 02:07 PM
  2. Replies: 9
    Last Post: 08-06-2012, 12:12 PM
  3. NEW MEMBER: Goal - Enable 3-Axis CNC Bed Mill to Perform 5-Axis Milling
  4. moves ok when using jog in mach3 but....
    By deannos in forum General Discussion
    Last Post: 28-12-2011, 09:40 PM
  5. Precision metal processing (3 axis, 5 axis, 7 axis) OEM
    By 7AxisCNC in forum Manufacturer News
    Last Post: 17-05-2011, 02:04 PM
