Page 3 of 6 FirstFirst 12345 ... LastLast
  1. #21
    When I toggle the z with the arrow keys it moves In inchs and the z and y move in mm
    Sent from my SM-G361F using Tapatalk
  2. #22
    Lives in Marple Stockport, United Kingdom. Last Activity: 18 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 3,333. Received thanks 618 times, giving thanks to others 78 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Quote Originally Posted by whensparksfly View Post
    How do you know it moves in inches? Does the X move in inches as well?
    You need to give more info about the settings on your machine etc.
  3. #23
    If Z is moving around 25 times further than required then the motor tuning for the Z axis is probably incorrect, it is most likely doing exactly what it has been told to do.
    Make sure tuning is correct may be totally different to X & Y and be sure to save axis settings every time changes are made, you solved the motor tuning problem with auto calibration in this or previous thread, how are you measuring that movement accurately with much smaller Z axis movement any errors may be larger.
  4. #24
    What setting do you mean I'm new to this
  5. #25
    The motor steps per unit in motor tuning.
  6. #26
    I done the automatic motor configuration in the setting menu measured it movement it was correct.
    When I toggle the z and y with the arow keys it will work in mm I can be seen that the movment matchs the fro but when z is moved the movement in the dro and a axis will move in inchs
  7. #27
    The only way that can happen is if you've got your motor tuning wrong.
    Motor tuning units are set for all axes at once so you can't have a mix.
    If tuning units are set to mm and X and Y work fine you will get really close if you take the number for "steps per" currently set for Z and multiply it by 25.4, Mach3 can't tell when you instruct it to do stupid things, it simply does what it's told.
    - Nick
  8. #28
    When I stated in your previous thread to check wiring you responded I was definitely wrong then that you had found the broken wire.
    When I stated the code was wrong and would not run in a different thread, you replied I was wrong and later PM'd me to get the edit to correct that code.
    Again I try all axis are using same measurement scales they cannot do otherwise, therefore your tuning steps per unit are incorrect they are for mm's if axis is moving in mm and for Inches or out by a factor of 2540% if axis is moving in inches instead of mm.
    There is no alternative computers just do what they are told, you put rubbish in you will only get rubbish out its the way it is.
  9. #29
    I started changing the motor tuning rather than the running in the setting.
    But when I run the code after setting zero the z just go's down past the materal down to the bed maybe I'm not setting the zero right.
    I'm very thankful for all your help don't think I'm not the pm was a personal thank you
  10. #30
    Quote Originally Posted by lucan07 View Post
    Can you show your working for the maths that give you this result? ;-)
  1. Replies: 9
    Last Post: 23-05-2015, 02:07 PM
  2. Replies: 9
    Last Post: 08-06-2012, 12:12 PM
  3. NEW MEMBER: Goal - Enable 3-Axis CNC Bed Mill to Perform 5-Axis Milling
  4. moves ok when using jog in mach3 but....
    By deannos in forum General Discussion
    Last Post: 28-12-2011, 09:40 PM
  5. Precision metal processing (3 axis, 5 axis, 7 axis) OEM
    By 7AxisCNC in forum Manufacturer News
    Last Post: 17-05-2011, 02:04 PM
