    Hi, I am using EMCO WIN32 Concept MILL. Now an error message appears as "BOOT ERROR 0019; Error registering a font!' and 'The instruction at "0*00412c2a" referenced memory at "0*00000462'. The memory could not be read'
    Click on OK to terminate the program.
    Can anyone give me a solution to this problem?
    Lee Roberts's Avatar
    Lives in Wigan, United Kingdom. Current Activity: Viewing Moderator Control Panel Has been a member for 9-10 years. Has a total post count of 2,556. Received thanks 170 times, giving thanks to others 656 times. Made a monetary donation to the upkeep of the community. Referred 10 members to the community.
    Bump...Bump
    .Me
    I know nothing of this machine, but the bios and eproms on PC motherboards can cause such errors when the backup batteries are low and they have been powered down for a while (normally 2032 3v coin batteries). If the machine has been disconnected from the power or powered down for any length of time recently I would check the board for such backup batteries and if possible replace, it is possible that on older machines it may be a PCB mounted rechargeable battery in which case not so simple.
    Quote Originally Posted by lucan07 View Post
    Thanks for your reply and suggestion. I have rectified it. Completely drained air from the machine, then switched on, its working !!!!!!!!!
  1. Emco pc mill 55 upgrade
    By Craiggillzzr1400zx10r in forum Emco Milling Machines
    Last Post: 31-08-2016, 03:13 AM
  2. FOR SALE: Emco mill 50 for sale
    Last Post: 05-04-2016, 07:37 PM
  3. CONVERSION: Emco Mentor Mill conversion
    By Ross77 in forum Conversion Build Logs
    Last Post: 13-01-2016, 06:40 PM
  4. FOR SALE: Emco mill 50 cnc mill like Denford Triac
    Last Post: 18-05-2014, 10:19 AM
  5. Emco mill 50 Y axis travel?
    By gavztheouch in forum Emco Milling Machines
    Last Post: 01-03-2014, 11:10 AM
