Thread: Keyed shafts
    Hi all I'm after some keyed shaft stock. I would need a few 300mm lengths of 12mm silversteel or similar bearing/bushing friendly material with 3mm keyways. Does anyone have any sources of where to buy this kind of thing? I don't have any friendly local places I can take some material to get machined sadly so that's not an option. If not is it best I put up a RFQ?
    Thanks,
    Harry.
    If you can cut keys or get done locally I use these for odds and ends they used to stock 300mm as standard seems to be 333mm now, delivery usually next day would be very surprised if not a small shop to do these near you, even a dremel and vice would possibly do trick depending on accuracy required and patience.
    https://www.cromwell.co.uk/shop/materials-and-maintenance/silver-steel/silver-steel-metric-round-sizes/f/1579?6292=12.
    Misumi would be my first bet
    https://emvioeng.com
  1. Replies: 0
    Last Post: 24-09-2014, 08:57 AM
  2. Shafts, bearings and circlips....
    By irving2008 in forum Linear & Rotary Motion
    Last Post: 01-10-2013, 09:52 AM
