    2 Steel plates
    2 Cuts
    Dimensions: 60x60mm ~ 120x120mm
    Thickness: 5mm ~ 1cm
    Steel Grade: Mild Steel or better, preferably something with better wear.
    I need the leaf shaped cut out and should not be discarded or damaged.
    Whatever technology offers the best tolerances.
    I also have the STL files, I gather these should be compatible with most machines.
    Nobody? Is there something technically wrong with that i'm asking for that perhaps I don't currently understand?
  1. Do you need to water cool erhm a water cooled spindle?!!
    By HankMcSpank in forum Generic Chinese Spindles
    Last Post: 02-10-2013, 08:59 PM
  2. Replies: 17
    Last Post: 18-09-2013, 05:32 AM
  3. Ok PCB milled now how to drill the holes ?
    By Fivetide in forum CAD & CAM Software
    Last Post: 12-05-2013, 07:31 PM
  4. Has anyone here milled ABS?
    Last Post: 11-02-2011, 07:17 AM
