    spindle encoder? do you mean rpm feedback into mach?
    the spindle doesn't affect the atc in any way. the z needs to be at the correct height so the atc disk can collect the tool, that's it.
    I don't use any temp sensors
    Quote Originally Posted by RocketBoy View Post
    Hi Andy,
    Thanks for the advice so far. I'm poor in money and time so I'm going to have to break this down into smaller chunks. So I'll concentrate on the spindle drive and control and get a V5 card. Can you tell me what you used for the spindle encoder, did you buy this or make it? Any pictures you could send me please?
    I do have a few more questions regarding the spindle, I've watched a few videos on YouTube of the ATC mechanism working. it looks like the spindle is positioned and locked in place, is there a mechanism within the motor spindle assembly that clicks in to do this? Or is aligned with the slot on the encoder and then motor braking is applied?
    Do I need to have any more inputs to the Sprint card such as breaking and the Taco? Lastly I have a temperature sensor wired in the spindle motor, does this do anything, do I need to use it?
    Mike
    Chaz's Avatar
    Lives in Ickenham, West London, United Kingdom. Current Activity: Viewing Has been a member for 4-5 years. Has a total post count of 963. Received thanks 67 times, giving thanks to others 42 times.
    Quote Originally Posted by andy_con View Post
    Ive done a Denford Triac mod to a CS Labs unit. I can help answer a few questions.
    1. The spindle drive needs to be isolated. A new sprint 1220i drive is around £250.
    2. The ATC needs that Z is set roughly at Z + 30 from home. This is set for me via my macro for M6 in Mach 3.
    You do not need a new sprint card, ignore that advice. You just need to use a v4 or v5 board, they work perfectly
  4. The Following User Says Thank You to andy_con For This Useful Post:
  5. #14
    Gents,
    Been away for a while, just catching up now. Thanks for all the input been very useful, especially Andy. Think I have enough to be getting on with now, sure I will have more questions down the line.
    Mike
  6. #15
    hi
    im rob i now own diycnc
    im always open to sugestions to improving products
    cheers rob
  7. #16
    Evening all,
    Really need some advice and help on how and what I need to control the spindle on my new Triac with MACH3. The machine as received is completely stripped of all electronics except for the spindle motor (SEM MT30U4-36) and drive card (Sprint 1200). So far I have managed to wire up the spindle motor and drive board and control it via a 10k pot and verify all works OK (Phew).
    The Mill also has an ATC unit that I will add to the conversion later on. What I'm trying to understand is how to control the spindle for the ATC alignment.
    My other question is could this setup be used for ridged tapping? I read somewhere that you would need to convert the spindle to an axis via software so the Z and spindle movements can be synchronised.
    The spindle motor has a Taco built in, can MACH use this for position or would I need to make a separate encoder disk with a slot and sensor?
    Lastly what BOB would people recommend, I would need this to control the spindle and ATC plus limit switches etc or would a PLC be better for the ATC??
    Lots of questions I know, if anyone could point me in the right direction I would be most grateful.
    Mike
    Hi, Do you still have the motion control card (electronics) you stripped off the machine. Precisely, I need a working “baldor D281 motion control card for a Triac P. C. (denford), red 7-segment LED display type". The firmware is ESMINT 3.28 V1.6H/S - JD5. Cheers.
  8. #17
    Benja's Avatar
    Lives in winchester, United Kingdom. Last Activity: 5 Hours Ago Has been a member for 1-2 years. Has a total post count of 28.
    is it still possible to buy the v4/5 spindle boards? DIY cnc seems to have disappeared.
  9. #18
    Quote Originally Posted by Benja View Post
    Hi
    I also need to replace the V4 board in Denford triac Mach 3 conversion. I contacted Roy formerly of diycnc who had this to say "Sorry, I sold the business back in 2015 to the guy who advertises the plasma cutters.
    He sold all the boards untill the end of last year but now just concentrates on his own machines.
    No spare boards, he had everthing."
    I did a little googling and found this https://cnc4pc.com/motion-control/sp...rol-board.html Do any of the members here think it could be a replacement for the old V4s? I'm not all that hot on electronics but it superficially looks like it may be similar.
  10. #19
    Benja's Avatar
    Looks like we both came up with the same research, it looked like it would work to me too, I did a bit of reading on it and it does seem like it would work coupled with the sprint board.
    The only other possible solution I came up with was coupling the UC300 ETH 5 LPT with a cheap Opto isolated bob with analogue outputs into the sprint. its a much more expensive option but would serve 2 purposes - 1. as a motion controller and replacing the parallel port with Ethernet. and 2. As the spindle speed control board. From what ive read it would work, but i havent gone that route yet myself so do your reasearch dont take my word for it!
    I'm someone will chime in and tell you a better option now ive mentioned it though.
  11. #20
    Hi Benja
    I spoke with my learned friend AngelTech (from the Denford data forum) last night and showed him the possible replacement board. He had this to say: "first off, no that board is no good for an unisolated spindle drive like you have. There is no dc isolation on the board. It would be ok for an isolated spindle drive or an inverter."
    So my new plan is to swap my brand new Sprint 1200 for the 1220i (fully isolated driver) and see if that works. I also spoke with Rob Rossini on the phone ( who was very helpful) who said he may be making some more V5 (the diycnc upgrade to the V4 boards) at some point soon.
  1. Denford Triac VMC
    By fidia in forum Milling Machines, Builds & Conversions
    Last Post: 19-08-2016, 08:18 AM
  2. FOR SALE: Denford Triac
    By asto in forum Items For Sale
    Last Post: 07-02-2016, 08:28 PM
  3. 3kw Chinese Spindle - ER20 denford triac question
    By andy_con in forum Denford Mills
    Last Post: 03-11-2015, 10:14 PM
  4. eBay: Denford Novamill SmartStep Control Board + Spindle Board
    By danielbriggs in forum Items On eBay UK
    Last Post: 30-05-2013, 06:52 AM
  5. Denford Triac Spindle Fault
    By Sam_Smith in forum Denford Mills
    Last Post: 04-05-2011, 11:07 PM
