Thread: Newbie hoping for acrylic advice
20-06-2016 #1
Hi all, one of my hobbies is fish keeping, I'm hoping to gain some advice on building acrylic aquariums in my spare time to sell to fellow hobbyists and maybe hopefully one day be successful enough to make a living from it
Sent from my SM-G925F using Tapatalk
21-06-2016 #2
Permanent structural Acrylic construction requires a "weld" achieved with a solvent cement.
Weldon 4 for bonding close fitting joints and I think it's Weldon 14 that's a gap-filling version, (I think 14 is effectively 4 with acrylic dissolved in it to allow it to fill gaps).
This might be an ideal application for Finite Element Analysis software to ensure your wall thicknesses keep distortion within acceptable limits, don't forget permanent cross bracing at the top of long tanks to prevent the long sides from splaying,
21-06-2016 #3
Cheers Nick.... most tanks I would start with would be small cubes 2ft x 2ft or smaller maybe slightly bigger until I get experience also I don't want to use bracing bars so will use thicker acrylic to compensate.
How do I cut and prepare the pieces before bonding ?
23-06-2016 #4
A commercial quality circular saw bench should be capable of cuts straight enough for bonding without excessive prep work.
24-06-2016 #5
The best way to cut such materials without chips, especially with a manual circular saw/yep, its possible/ is to stick a normal transparent tape both sides of the cut and cut through it. It lubricates the blade, dont ask me why. Even best is a sacrificial cheap high density foam sheet below the methacrylate , especially if cutting over edge of table using hand saw.
Saw blade must be meant for plastic / more teeth/, from the web manufacturer recommendations:
"For best results with Plexiglas® MC acrylic sheet, circular saw blades should be the largest diameter possible and contain 60 carbide-tipped teeth with a triple-chip-tooth design. Teeth should be shaped with a 5° to 10° positive rake angle and have sharp cutting edges with adequate clearance."
As far as structural strength when gluing aquariums.
i would do my self an DIy acrylic sheet bender. Which simply said is a heated wire that heats a line of material when place near it on top of material, and then bend material over some edge. This is the simplest contraption and it works. Now that you have the facing toward the viewer edges without glue and beautifully executed/ no glue and slightly curved for strength/ you could procede and glue the rest properly with additional reinforcing strip.
I am never ashamed to do it beautiful where must be and strong, where must be. Speaking in general. the above i know from a friend making transparent covers for his beautiful yacht models.
Hope that helps
24-06-2016 #6
Most commercial builders of aquaria use bonded square corners in tanks even with capacities of thousands of gallons, the adhesives are not a "glue" they are a mixture of solvent and acrylic and if properly used produce a weld. Cylindrical tanks are manufactured by bending a sheet into a ring and solvent/acrylic welding the joint, this is subsequently sanded and polished to a near invisible join.
I wouldn't buy a tank with a bent corner in it unless I'd specified that in my order, I'd go to a manufacturer capable of working with industry standard materials to industry standards.You think that's too expensive? You're not a Model Engineer are you? :D
24-06-2016 #7
24-06-2016 #8
It's far harder to shatter, under prolonged stress it cold-flows rather than deflecting until it reaches failure point, the tank is one welded component with the associated reduction in risk of long-term leak formation at adhesive/build-material interfaces.......
24-06-2016 #9
Well my prefered method of containing fish is in my Belly. . . .Yum Yum.
Hey, now we have Britian Back and our Fishing waters will the price of Fish n Chips come down.?
25-06-2016 #10
Does anyone know the best place to get the acrylic ?... what's the acrylic described as here in the UK... do I just ask/search cast acrylic ?
RFQ: Advice for a newbie, please - holes and spheres - 5 axis drilling
By alixus in forum Projects, Jobs & RequestsReplies: 0Last Post: 06-05-2015, 02:39 PM -
Acrylic or mdf I can cnc
By rainboweyes in forum Opportunities Available & SoughtReplies: 0Last Post: 19-02-2013, 02:09 AM -
Which controller and motors? Newbie advice please
By Nealieboyee in forum Motor Drivers & ControllersReplies: 14Last Post: 16-10-2012, 02:56 PM -
newbie need advice on cnc machine to purchase? routoutcnc machines any good?
By wyndham in forum Milling Machines, Builds & ConversionsReplies: 9Last Post: 27-05-2011, 08:54 PM -
NEW MEMBER: New Member, saying Hello and hoping for direction
By GMNOCNC in forum New Member IntroductionsReplies: 0Last Post: 07-03-2011, 11:50 AM
