30-06-2016 #1
hi, I have buy a new proxxon MF70, and I want find all parts for convert it...
by first steep - I want replace the motor and spindle original with a motor brushless and spindle ER-11 and your bearings
by second steep - extend table Y
by third steep - convert to cnc with nema 23, supports for them, controller and drivers.
for steep 1 - by check on web info, I have found a discussion about the replacement of only spindle with a new ER-11 spindle diameter 10 and 12 mm but on motor original. Also I have a dubt
I not found a real conversion with more details for buy a right spindle and motor together, my dubt: what motor I will buy ? what size power watt (300w up to 400w) ? What motor better that fit in head proxxon without make a big modify ? what type and right spindle ER-11 (C10-ER11A-100L or C12-11A-100L to mount on motor original proxxon) ?
C10 = 10mm diameter C12 = 12mm.
Someone have a link or right istructions how to make this mod with all parts details ?
30-06-2016 #2
Some links:
PROXXON - MF 70/CNC-ready
Building the KRmf70 CNC — Kronos Robotics
Proxxon MF70 Miller CNC CONVERSION - theBox
Should get you started with some of your questions.
.Me.Me
30-06-2016 #3
I used to have an MF70 and documented extending the Y axis here:
https://0xfred.wordpress.com/2012/04...-mf70s-y-axis/
Why change the spindle? I doubt the tiny mill could handle much more power.
30-06-2016 #4
I° case : I have think if leaves a original motor ,I will change only the spindle same diameter 10mm but have a ER11 chuck for drill up to 7mm.
II° case, if I will replacement motor original with a bushless power up to 400-500Watt, I need increase the diameter spindle because the new bushless motor have more power..
28-07-2016 #5
the diameter of shank er11 is same the diameter bearing proxxon mf70 , I have also a new motor brushless 600watt power.
12-12-2017 #6
Old post but...can you give some details about motor, adapters, spindle etc? I have a burned MF70 motor and it's time to move to a brushless one...
19-02-2018 #7
I have modify my MF70 with the brushless and spindle ER11, also I think of convert the MF70 to CNC.
So I have already the breakboard 5 axis and motors stepper with each drivers.
The motors is a turnigy-aerodrive-sk3-3542-1250kv, the speed controller Turnigy dlux 70A SBEC Brushless Speed Controller and for variable speed I use a servo tester.
I had modified also the head of mill with a gear and belt.
Now I need of know how to control the motor brushless and speed controller with my cnc card.
Someone of this post can help me ?Last edited by cnc.miller; 19-02-2018 at 04:44 PM.
WANTED: Wanted: Proxxon MF70 Desktop Milling Machine or Similar
By jnash in forum Items WantedReplies: 2Last Post: 25-01-2016, 05:02 PM -
WANTED: Proxxon MF70
By jnash in forum Items WantedReplies: 0Last Post: 12-05-2015, 03:52 PM -
Proxxon MF70 for making injection molds
By forrest in forum Moulding MachinesReplies: 8Last Post: 11-04-2012, 11:30 PM -
Z-axis huge slack / beginning a conversion
By diy-john in forum Gantry/Router Machines & BuildingReplies: 11Last Post: 04-03-2012, 10:26 PM -
FOR SALE: Proxxon MF70 XXL 320
By fidia in forum Items For SaleReplies: 1Last Post: 20-05-2011, 02:35 PM
