    Been learning Aspire for some CAM work, it seems to have a bug with simple circles where it generates G-Code with hundreds of straight lines?
    Here is a simple test file - it contains two paths, first is a square with 10mm radiused corners which works perfectly. The second is a simple circle and as you can see it has used loads of straight lines this time.
    Profile 2.tap.zip
    Can this be fixed at all, I am using the post for Mach3 with Arcs and ATC.
    Dave can you post the Aspire file up?
    I have just drawn a simple circle in Aspire and put it through the MAch3 post without any problems.
    Have you done the cad in Aspire or imported from another cad package there is a command to close vectors with a smooth curve
    Daft question, maybe, but did you draw the circle in Aspire or import a dxf from elsewhere? I had similar problems a little while ago because I had saved the dxf in the wrong version so it ended up as a series of line segments rather than arcs.
    Hi
    the file was just a quick mess about for testing the motion on my mill conversion project.
    It was all done inside Aspire.
    File attached
    Test junk.zip
    I just made a similar file in my CAD app and converted it in Aspire and its just as bad, converted in SheetCam and its perfect - about 15 lines of code :)
    Seems to be an aspire bug?
    Dave when I draw a circle in my Aspire it is fine when I did another circle on your drawing it is also fine. Did you draw the circle in Aspire
    The post I am using is Mach2_3_Arcs_mm.pp
  1. Aspire v4.5
    By m.marino in forum Vectric
    Last Post: 16-05-2015, 04:44 PM
  2. Replies: 47
    Last Post: 13-02-2014, 11:49 PM
  3. control signals to draw a circle
    By lakmalp in forum Machine Control Software
    Last Post: 16-06-2013, 05:52 PM
  4. Cutting out a circle
    By Martin Paul in forum Machine Discussion
    Last Post: 19-04-2011, 12:58 AM
  5. Aspire !!!
    By james mcgrew in forum CAD & CAM Software
    Last Post: 17-01-2009, 02:16 AM
