    Hi simple question probably easy for you guys, I need to reverse my stepper motor direction and I know its a matter of swapping wires around but I'm not sure which ones , so some help would be gratefully appreciated
    My wiring set up is the one on the right below 21 kg
    Ralph Waldo Emerson
    Just swap one coil pair, say A- and A+.
    Best Regards
    picclock
    Quote Originally Posted by picclock View Post
    Best Regards
    picclock
    Thanks for the reply.. I'd like a confirmation for this from someone with a few more posts than 2 before wiring up a very expensive controller .. no disrespect intended picclock
    Ralph Waldo Emerson
    Lives in Marple Stockport, United Kingdom. Last Activity: 13 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 3,333. Received thanks 618 times, giving thanks to others 78 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Quote Originally Posted by Fivetide View Post
    Yes, you can just reverse one pair of windings, you can also do it in software by inverting the the dir pulse.
    thanks Clive I'm experimenting with GrBl panel atm couldn't figure out how to do it in the software lol I'll swap A+ to A- on your advice :)
    Ralph Waldo Emerson
    worked a treat thanks for the help
    Ralph Waldo Emerson
    Always best to check. Glad you got it going
  8. The Following User Says Thank You to Clive S For This Useful Post:
  9. #8
    God advice :) I'm nearly there just got to fit and configure the hard stops - case up the electronics - fit it to the lathe and I'm ready for a test run
    Ralph Waldo Emerson
  1. Stepper Motor Wiring
    By ravihotwok in forum General Electronics
    Last Post: 26-07-2017, 10:41 AM
  2. Stepper motor tunning wiring
    By handyoodman03 in forum Stepper & Servo Motors
    Last Post: 11-01-2013, 05:49 PM
  3. Stepper motor wiring
    By Buba b in forum Stepper & Servo Motors
    Last Post: 28-03-2010, 06:16 PM
  4. Stepper Motor Wiring (Screened?)
    By pequod in forum Stepper & Servo Motors
    Last Post: 03-08-2009, 10:15 AM
  5. Reversing motor direction in Mach3
    By bruce_miranda in forum Artsoft Mach (3 & 4)
    Last Post: 16-11-2008, 06:54 PM
